First attempt to add support for Radxa Rock 3C
I noticed today that there was no build created yet for Radxa Rock 3C. I found the Rock 3A config file at build/config/boards/rock-3a.conf : # Rockchip RK3568 quad core 1-8GB SoC GBe eMMC USB3 BOARD_NAME="Rock 3A" BOARDFAMILY="rk35xx" BOOTCONFIG="rock-3a-rk3568_defconfig" KERNEL_TARGET="legacy,current,edge" FULL_DESKTOP="yes" BOOT_LOGO="desktop" BOOT_FDT_FILE="rockchip/rk3568-rock-3a.dtb" BOOT_SCENARIO="spl-blobs" WIREGUARD="no" BOOT_SUPPORT_SPI="yes" BOOT_SPI_RKSPI_LOADER="yes" IMAGE_PARTITION_TABLE="gpt" BOOTFS_TYPE="fat" And copied it to build/boards/rock-3c.conf . Then modified it to # Rockchip RK3566 quad core 1-8GB SoC GBe eMMC USB3 BOARD_NAME="Rock 3C" BOARDFAMILY="rk35xx" BOOTCONFIG="rock-3c-rk3566_defconfig" KERNEL_TARGET="legacy,current,edge" FULL_DESKTOP="yes" BOOT_LOGO="desktop" BOOT_FDT_FILE="rockchip/rk3566-rock-3c.dtb" BOOT_SCENARIO="spl-blobs" BOOT_SUPPORT_SPI="yes" BOOT_SPI_RKSPI_LOADER="yes" IMAGE_PARTITION_TABLE="gpt" BOOTFS_TYPE="fat" And was pleasantly surprised when it was able to build an image! 🙂 However, the booting was not so successful I get this on the UART (1500000 bps 8N1): DDR Version V1.10 20210810 ln ddrconfig:0 LP4 MR14:0x4d LPDDR4, 324MHz BW=32 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=4096MB tdqss: cs0 dqs0: 361ps, dqs1: 289ps, dqs2: 313ps, dqs3: 217ps, change to: 324MHz PHY drv:clk:38,ca:38,DQ:30,odt:0 vrefinner:41%, vrefout:41% dram drv:40,odt:0 clk skew:0x58 change to: 528MHz PHY drv:clk:38,ca:38,DQ:30,odt:60 vrefinner:16%, vrefout:41% dram drv:40,odt:0 clk skew:0x78 change to: 780MHz PHY drv:clk:38,ca:38,DQ:30,odt:60 vrefinner:16%, vrefout:41% dram drv:40,odt:0 clk skew:0x5c change to: 1056MHz(final freq) PHY drv:clk:38,ca:38,DQ:30,odt:60 vrefinner:16%, vrefout:29% dram drv:40,odt:80 vref_ca:00000068 clk skew:0x3f cs 0: the read training result: DQS0:0x3b, DQS1:0x3d, DQS2:0x3d, DQS3:0x38, min : 0x9 0xa 0xc 0x9 0x1 0x2 0x5 0x2 , 0x8 0x9 0x5 0x1 0xb 0xd 0xf 0x9 , 0xd 0xb 0xc 0x8 0x4 0x1 0x4 0x6 , 0xb 0x6 0x6 0x1 0xf 0xe 0xd 0xe , mid :0x28 0x29 0x2b 0x28 0x1f 0x21 0x23 0x21 ,0x26 0x27 0x22 0x1f 0x29 0x2b 0x2c 0x27 , 0x2b 0x2a 0x29 0x27 0x22 0x1f 0x21 0x23 ,0x28 0x23 0x23 0x1f 0x2b 0x2b 0x29 0x2b , max :0x48 0x49 0x4b 0x47 0x3e 0x40 0x42 0x41 ,0x45 0x45 0x40 0x3e 0x47 0x49 0x4a 0x46 , 0x4a 0x49 0x46 0x46 0x41 0x3e 0x3f 0x41 ,0x45 0x41 0x40 0x3d 0x48 0x48 0x46 0x49 , range:0x3f 0x3f 0x3f 0x3e 0x3d 0x3e 0x3d 0x3f ,0x3d 0x3c 0x3b 0x3d 0x3c 0x3c 0x3b 0x3d , 0x3d 0x3e 0x3a 0x3e 0x3d 0x3d 0x3b 0x3b ,0x3a 0x3b 0x3a 0x3c 0x39 0x3a 0x39 0x3b , the write training result: DQS0:0x6f, DQS1:0x66, DQS2:0x69, DQS3:0x5c, min :0x95 0x97 0x99 0x97 0x8f 0x92 0x94 0x94 0x94 ,0x88 0x88 0x86 0x83 0x8d 0x8e 0x8e 0x8d 0x89 , 0x92 0x91 0x8e 0x8e 0x89 0x87 0x8a 0x8e 0x8d ,0x86 0x85 0x83 0x7f 0x8a 0x8a 0x88 0x8c 0x85 , mid :0xb2 0xb4 0xb6 0xb3 0xab 0xad 0xaf 0xae 0xae ,0xa6 0xa5 0xa1 0x9e 0xaa 0xaa 0xa9 0xa9 0xa6 , 0xaf 0xae 0xab 0xaa 0xa5 0xa1 0xa3 0xa9 0xa9 ,0xa4 0xa1 0xa0 0x9b 0xa7 0xa7 0xa5 0xa8 0xa2 , max :0xd0 0xd1 0xd3 0xcf 0xc7 0xc9 0xcb 0xc9 0xc9 ,0xc4 0xc3 0xbd 0xba 0xc7 0xc7 0xc5 0xc5 0xc3 , 0xcd 0xcb 0xc8 0xc6 0xc2 0xbc 0xbc 0xc4 0xc6 ,0xc2 0xbd 0xbd 0xb8 0xc5 0xc5 0xc2 0xc5 0xc0 , range:0x3b 0x3a 0x3a 0x38 0x38 0x37 0x37 0x35 0x35 ,0x3c 0x3b 0x37 0x37 0x3a 0x39 0x37 0x38 0x3a , 0x3b 0x3a 0x3a 0x38 0x39 0x35 0x32 0x36 0x39 ,0x3c 0x38 0x3a 0x39 0x3b 0x3b 0x3a 0x39 0x3b , CA Training result: cs:0 min :0x3d 0x35 0x37 0x2d 0x37 0x2c 0x38 ,0x3f 0x34 0x37 0x2c 0x37 0x2a 0x3c , cs:0 mid :0x78 0x79 0x71 0x70 0x71 0x6f 0x63 ,0x79 0x77 0x71 0x6f 0x70 0x6e 0x67 , cs:0 max :0xb3 0xbd 0xab 0xb3 0xab 0xb3 0x8e ,0xb4 0xbb 0xac 0xb2 0xaa 0xb2 0x92 , cs:0 range:0x76 0x88 0x74 0x86 0x74 0x87 0x56 ,0x75 0x87 0x75 0x86 0x73 0x88 0x56 , out U-Boot SPL board init U-Boot SPL 2017.09-armbian (Jun 10 2023 - 09:59:15) unknown raw ID phN unrecognized JEDEC id bytes: 00, 00, 00 Trying to boot from MMC2 ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(5938a9cdfc...) + OK ## Checking uboot 0x00a00000 ... sha256(d801f0f359...) + OK ## Checking fdt 0x00b2e6f8 ... sha256(3ccee0dc53...) + OK ## Checking atf-2 0x00068000 ... sha256(0965dc8022...) + OK ## Checking atf-3 0xfdcd0000 ... sha256(be991af043...) + OK ## Checking atf-4 0xfdcc9000 ... sha256(695349eb36...) + OK ## Checking atf-5 0x00066000 ... sha256(315a4195a9...) + OK Jumping to U-Boot(0x00a00000) via ARM Trusted Firmware(0x00040000) Total: 237.208 ms INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-167-g81e0b993a-dirty:xsf NOTICE: BL31: Built : 11:20:08, Sep 6 2021 INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: pmu v1 is valid INFO: dfs DDR fsp_param[0].freq_mhz= 1056MHz INFO: dfs DDR fsp_param[1].freq_mhz= 324MHz INFO: dfs DDR fsp_param[2].freq_mhz= 528MHz INFO: dfs DDR fsp_param[3].freq_mhz= 780MHz INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0xa00000 INFO: SPSR = 0x3c9 U-Boot 2017.09-armbian (Jun 10 2023 - 09:59:15 +0200) Model: Radxa ROCK3 Model C PreSerial: 2, raw, 0xfe660000 DRAM: 4 GiB Sysmem: init Relocation Offset: ed34a000 Relocation fdt: eb9f63c0 - eb9fecc8 CR: M/C/I Using default environment failed to find reset-gpios property no mmc device at slot 1 dwmmc@fe2b0000: 1 (SD), dwmmc@fe2c0000: 2, sdhci@fe310000: 0 Bootdev(atags): mmc 1 MMC1: Legacy, 52Mhz PartType: EFI No misc partition boot mode: None FIT: No boot partition No resource partition No resource partition Failed to load DTB, ret=-19 Failed to get kernel dtb, ret=-19 I2c0 speed: 100000Hz vsel-gpios- not found! Error: -2 vdd_cpu init 900000 uV PMIC: RK8090 (on=0x40, off=0x00) vdd_logic init 900000 uV vdd_gpu init 900000 uV vdd_npu init 900000 uV io-domain: OK Model: Radxa ROCK3 Model C rockchip_set_serialno: could not find efuse/otp device CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A) apll 816000 KHz dpll 528000 KHz gpll 1188000 KHz cpll 1000000 KHz npll 1200000 KHz vpll 24000 KHz hpll 24000 KHz ppll 200000 KHz armclk 816000 KHz aclk_bus 150000 KHz pclk_bus 100000 KHz aclk_top_high 300000 KHz aclk_top_low 200000 KHz hclk_top 150000 KHz pclk_top 100000 KHz aclk_perimid 300000 KHz hclk_perimid 150000 KHz pclk_pmu 100000 KHz No misc partition Net: eth1: ethernet@fe010000 Hit key to stop autoboot('CTRL+C'): 0 failed to find reset-gpios property Device 0: unknown device switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot.scr reading /boot.scr 3252 bytes read in 2 ms (1.6 MiB/s) ## Executing script at 00c00000 Boot script loaded from mmc 1 reading /armbianEnv.txt 151 bytes read in 1 ms (147.5 KiB/s) reading /uInitrd 21588378 bytes read in 1795 ms (11.5 MiB/s) reading /Image 29331968 bytes read in 2437 ms (11.5 MiB/s) ** Unable to read file /dtb/rockchip/rk3566-rock-3c.dtb ** libfdt fdt_check_header(): FDT_ERR_BADMAGIC No FDT memory address configured. Default at 0xeb9f63c0 ** Unable to read file /dtb/rockchip/overlay/rk35xx-fixup.scr ** Unknown command 'kaslrseed' - try 'help' Fdt Ramdisk skip relocation No misc partition ## Loading init Ramdisk from Legacy Image at 0a200000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 21588314 Bytes = 20.6 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ERROR: Did not find a cmdline Flattened Device Tree Could not find a valid device tree SCRIPT FAILED: continuing... MMC error: The cmd index is 0, ret is -110 mmc_init: -110, time 4 starting USB... Bus dwc3@fcc00000: CTRL-A Z for help | 1500000 8N1 | NOR | Minicom 2.8 | VT102 | Offline | ttyUSB0 And no output on the HDMI. Any hints on what direction to dig for getting it closer to booting would be appreciated? / Kenneth
Endian
