TVBOX M4xq with ik316 EMCP 1.0
Guys, does anyone know how to enable the TV Box's wifi with the ik316 process? I downloaded armbian, the only thing missing is wifi. Data transmission works with a network cable, only the wifi is having problems. The iso I downloaded was Armbian-unofficial_25.05.0-trunk_X96q-lpddr3_bookworm_edge_6.12.11_xfce_desktop.img.xz
how to enable wifi (SV6256P) in H616 DDR3 Tv box
@SteeMan Do you mean moving to TV Box Wi-Fi folder?
@Nick A The fact that the kernel is old, interferes with finding a driver for wifi ?
When select the option of install the driver of wifi, return a message error: Invalid overlay_prefix sun50i_h616 @Nick A
It worked, thanks!
Where can i find it the armbian-config? And what a do it when find this for install the linux in flash memory? @Nick A
Apparently it worked, but stay in sd card and no in flash memory @Nick A
This https://github.com/warpme/miniarch/releases/download/gdde1069c/MiniArch-20240715-6.14.0-board-h313.x96_q_lpddr3_v1.3-SD-Image.img.xz
@Nick AAfter a lot of searching I found an ISO that my TV box "accepts", by reading the card with it, but every time I try to install mini arch, instead of installing in the flash memory, it installs via the SD card and I want it to be in the TV box's memory, how can I solve this?
@Nick A A forced installation on the TV box? But isn't there a chance of a problem?
@Nick A And how use this for install linux?
@Nick A I tested the image you sent, but it remains a black screen. Does this black screen mean that the TV box is trying to read it, but is unable to do so, or is it something else?
@Nick A Is it possible to use those programs to install firmware on these TV boxes to install Linux? Like phoenixusbpro, phoeniscard or phoenixsuit?
Nick F
