Skip to content
View in the app
Armbian Community Forums
OrangePI PC GPIO serial and IR reveiver
Featured Replies
am new on orangePI, Hope my question is not to dumb.
I am using the Armbian_5.05_Orangepih3_Debian_jessie_3.4.110.raw image.
Kernel is
Linux orangepipc 3.4.110-sun8i #18 SMP PREEMPT Tue Mar 8 20:03:32 CET 2016 armv7l GNU/Linux
I want to access a serial device connectet to the pins 8 and 10 on the GPIO connector, described at uart 3.
/dev/ttyS0 is the 3 connector pin close to the power plug.
there is no /dev/ttySn with n>0 and the /dev/ttyGSn are also not the ones to use.
How can I create the right device?
Same about the IR receiver, Is there any device that represents the IR receiver?
Are there modules to load?
thanks a lot for help
Regarding UARTs it's easy: They're disabled by default and the pins might be defined as GPIO. So you need bin2fex and fex2bin and adjust the following to your needs:
https://github.com/igorpecovnik/lib/blob/master/config/fex/orangepipc.fex#L166-L191
Regarding parameters please have a look at http://linux-sunxi.org/Fex_Guide#uart_configuration
And keep in mind that when you enable UART interfaces, the pins used there have to be commented/removed in the [gpio_para] section!
Regarding IR please have a look at http://irclog.whitequark.org/linux-sunxi/2016-04-28#16304769;and report back :)
  • Author
UARTS: I followed the instructions from tkaiser. Success :) Thank you.
About the IR reveiver: I found that the module sunxi_cir provides me a working /dev/lirc0 device.
Did not see that before.
One more question: where do i find documentation about the mapping of the pins described in script.fex (like PAXX, PCXX, PGXX) to the actual physical mapping on my Orange PI PC board?
Thanks, I like that forum :)
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
