Skip to content
View in the app
Armbian Community Forums
Sound only coming out of 1 speaker
Featured Replies
I'm testing out the Orange Pi 3 Ubuntu 18.04 image (Link: https://www.armbian.com/orange-pi-3/), and I'm trying to play some sound using a USB adapter (Link: https://www.amazon.co.uk/gp/product/B000R5NJD8/).
I originally posted this as a question on Ask Ubuntu (link: https://askubuntu.com/questions/1163369/sound-only-1-speaker-is-working), but I was advised to file a bug report about the issue.
I'm acutely aware that this post belongs in the Allwinner H6 forum (Link: https://forum.armbian.com/forum/18-allwinner-h6/), but it would appear that there are restrictions in place to prevent me from posting there.
It works...... but only through the left speaker. If I do this:
speaker-test --test wav --channels 2
...I hear "front right" out of the front-left speaker, and I do not hear "front left" at all. If I instead test just 1 channel:
speaker-test --test wav --channels 1
...then I hear "front left" out of the front-left speaker.
The same goes for if I play some music with `aplay`:
aplay test.wav
I ran the `alsa-info` program, and got this link, which contains a bunch of useful information: https://alsa-project.org/db/?f=39d0b2d680cd04a510e0bc0615d7ba771f4b29d2
I've checked the levels in `alsamixer` already: https://i.stack.imgur.com/N7U0f.png (Link to screenshot of the terminal)
alsamixer -c1
Additionally, I checked the USB adapter in question on another (also Ubuntu) machine (that has a GUI) (`alsa-info` link: https://alsa-project.org/db/?f=2f7f9550539333685966e7fd35ace8524281ba40). Both channels worked flawlessly as intended.
I do have PulseAudio installed, but playing through that yields the exact same problem.
Does anyone know what's gone wrong? I'd very much like to listen to things through both speakers.
We don't file 3rd party hardware bugs neither. Armbian is small amateur based project focused to onboard hw, which is hard enough, with virtually no budget for R&D.
Not anymore. But that does not change anything for you - it was only to lower our costs.
This issue is more or less generic (moving to peer to peer section) and tied to this particular (5.1.y) kernel I would guess. Most simple thing which you can do is to compare kernel configurations between working and non-working one, especially in sound section. Then check LKML for alsa related bugs ... and if/when you find a problem, submit a patch.
  • Author
Hey! Many thanks for the reply, @Igor. I tried my best to find the most appropriate place, but I must have gotten confused :P
I see. How would I go about doing that? Where can I find the appropriate kernel configurations to compare please?
Not sure I know what "LKML" refers to, sorry.
I assume that would be against a git repository somewhere? I'm certainly open to doing so, but it sounds rather intimidated at the moment :P
Solution is not simple. Not for me and I guess also not for you.
Ours: https://github.com/armbian/build/tree/master/config/kernel
General: https://www.google.com/search?q=how+to+obtain+a+kernel+config+from+running
Google. You won't believe, 1st hit ;)
https://docs.armbian.com/Process_Contribute/
It could be something like this: https://github.com/armbian/build/pull/1403
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
