Skip to content
View in the app
Armbian Community Forums
No Analog audio out
Featured Replies
Hi im using Orange Pi Zero +2 H3 with the current armbian image. 4.19 y  i think...
basically Im using HDMI out but i want to use the analog audio pins on my project. However the pins seem to be disabled and there doesnt appear any way to enable them. alsamixer only shows the allwinner,HDMI but no controls...
Pulse audio panel seems less than helpfulp, lists Analogoutput but doesnt actually send any sound out through the pins.
I warn you im not a linux power user. I can just about get around terminal but I dont know where files are off by heart or know exactly what and where to edit.
So maybe a little hand holding :)
Reading the forums a little people talk about editing a audio.conf file but having a look in the location they mention, no such file exists.
if anyone knows this issue and a sure fire way to fix it please let me know :)
Thanks
Mangy_Dog
first do enable analog-codec in armbian-config --> system --> hardware and reboot
then aplay -l
should also show the analog audio card.
then you could create for the cardno of the analog audio a /etc/asound.conf file ;)
  • Author
And still no asound.conf file.
What soznd-command?
To test speakers im just using some ogg/mp3 files in the built in media player
create a file /etc/asound.conf with the following content:
pcm.!default {
    type hw
    card 0
    device 0
ctl.!default {
    type hw
    card 0
  • Author
amazing thanks :D It was really quiet but in alsamixer i maxed out the DAC and turned up the lineoput a little
sounds great.
  • Author
anyway to keep the dac maxed out?
I mean how do i change the default settings or are they saved between restarts?
after you set the volume with alsamixer use
alsactl store
with alsactl you could also backup (store) and restore from a save-file
see -f option at
https://linux.die.net/man/1/alsactl
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
