Skip to content
View in the app
Armbian Community Forums
Questions of OrangePi Plus 2
Featured Replies
I have a OrangePi Plus 2.
I want to build images of desktop and no desktop.
I build Debian and works fine.
But for desktop only debian works not ubuntu xenial. It not boot.
Also in Desbian when I can add external Button to can start pc with it ? like a real computer ?
Tat's normal when i connect to DC it take a time to start ?
Thanks
Not possible to power on, only power off and standby/resume. You need to cut / add power.
Xenial is not full ready yet. Stick to Jessie.
  • Author
I need to add power ? And When I can add t ? I'm not sure where I can branch ? And must do a program to works with button ?
Thanks for respond
  • Author
That normal that when I want to compile this night I have :
[ warn ] ... u-boot-01-add-h3-gpio-support.patch [ failed ]
[ o.k. ] ... u-boot-02-support-cheap-mmc.patch [ succeeded ]
[ warn ] ... u-boot-03-add-R_PIO-support.patch [ failed ]
and after :
 DTC     arch/arm/dts/sun8i-h3-orangepi-2.dtb        ERROR (duplicate_node_names): Duplicate node name /clocks/apb0_clk─────────────────────────────────────────────────────────────────────────────────────────────────┘
      HOSTCC  tools/common/image.o                          ERROR (duplicate_node_names): Duplicate node name /clocks/clk@01f01428
  │ dts/Makefile:36 : la recette pour la cible « arch-dtbs » a échouée        │
  │ Makefile:821 : la recette pour la cible « dts/dt.dtb » a échouée        │
]: *** [arch/arm/dts/sun8i-h3-orangepi-2.dtb] Erreur 2
                                     ERROR (duplicate_make[1]: *** [arch-dtbs] Erreur 2/soc/pinctrl@01f02c00
        make: *** [dts/dt.dtb] Erreur 2ut tree has errors, aborting (use -f to force output)
[ error ] ERROR in function compile_uboot [ common.sh:89 ]
[ error ] U-boot file not found [ u-boot-sunxi-with-spl.bin ]
[ o.k. ] Process terminated
Thanks for help
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
