Skip to content
View in the app
Armbian Community Forums
HowTo create WiFi AdHoc (WEP) connect?
Featured Replies
I'm buying WiFi Dongle RTL8188 and want create WiFi AdHoc (WEP) connect PC<->OrangePi PC
HowTo settings on Armbian?
i'm install
sudo apt install network-manager-gnome
after try connect to wifi adhoc (WEP) from network-manager (nm-applet), show error:
(32) Not authorized to control networking
My settings:
userous@orangepipc:~$ groups
userous dialout sudo audio video plugdev netdev
cat /etc/network/interfaces
   auto lo   iface lo inet loopback
First guess... you must be member of group... I can't remember, I guess it will be netdev or similar. Just google for that, make your user part of that group and then maybe the issue is solved
You will probably need to delete configuration from /etc/network/interfaces (easiest way) for wlan0 or modify it to take wifi under network-manager control. If you want to do it by second way you must be added to netdev group and have netdev information in wpa supplicant config.
Sent from my Redmi Note 2 using Tapatalk
Can you please log in your OrangePi as root and post output of command below.
Do not post sensitive information like name and password of your wifi network. Replace it with xxx symbols for example.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
