Skip to content
View in the app
Armbian Community Forums
Wifi Down after last update
Featured Replies
at OPI PC with kernel
Linux orangepipc 3.4.112-sun8i #30 SMP PREEMPT Sat Apr 30 19:49:10 CEST 2016 armv7l GNU/Linux
before the last kernel update we use rt2800 wifi dongle.
dmesg | grep usb - shows this output:
[    0.963044] usbhid: USB HID core driver
[  169.650117] usb 3-1: new high-speed USB device number 2 using sunxi-ehci
[  169.948904] usbcore: registered new interface driver rt2870
after the last kernel update with apt-get update in 2016-06-08 which include these updates:
Start-Date: 2016-06-08  10:31:45
Commandline: apt-get upgrade
Upgrade: linux-jessie-root-orangepih3:armhf (5.10, 5.11),
libavdevice53:armhf (0.8.17-2+rpi1, 0.8.17-2+rpi1+deb7u1),
ffmpeg:armhf (0.8.17-2+rpi1, 0.8.17-2+rpi1+deb7u1),
linux-headers-sun8i:armhf (5.10, 5.13),
libavfilter2:armhf (0.8.17-2+rpi1, 0.8.17-2+rpi1+deb7u1),
libavutil51:armhf (0.8.17-2+rpi1, 0.8.17-2+rpi1+deb7u1),
linux-image-sun8i:armhf (5.10, 5.13),
linux-firmware-image-sun8i:armhf (5.10, 5.13),
libswscale2:armhf (0.8.17-2+rpi1, 0.8.17-2+rpi1+deb7u1),
libtasn1-3:armhf (2.13-2+deb7u2, 2.13-2+deb7u3),
libavformat53:armhf (0.8.17-2+rpi1, 0.8.17-2+rpi1+deb7u1),
libavcodec53:armhf (0.8.17-2+rpi1, 0.8.17-2+rpi1+deb7u1),
linux-u-boot-orangepih3-default:armhf (5.10, 5.11)
End-Date: 2016-06-08  10:37:13
OPI PC doesn't recognize the dongle.
[    1.288828] android_usb gadget: android_usb ready
[    1.454317] usbcore: registered new interface driver usbhid
[    1.457759] usbhid: USB HID core driver
[   45.436509] usb 4-1: USB disconnect, device number 2
[   49.250132] usb 4-1: new high-speed USB device number 3 using sunxi-ehci
One solution is to downgrade these updates, but that isn't the right way to do this, so can you give a tip how to fix that?
  • Author
I try every usb port and nothing change
[    0.000000] Booting Linux on physical CPU 0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 3.4.112-sun8i (root@pluton) (gcc version 5.3.1 20160413 (Ubuntu/Linaro 5.3.1-14ubuntu2) ) #8 SMP PREEMPT Tue May 31 19:00:17 CEST 2016
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: sun8i
[    0.000000] cma: CMA: reserved 256 MiB at 50000000
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] On node 0 totalpages: 262144
[    0.000000] free_area_init_node: node 0, pgdat c0a35380, node_mem_map c0b76000
[    0.000000]   Normal zone: 1710 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 192850 pages, LIFO batch:31
[    0.000000]   HighMem zone: 594 pages used for memmap
[    0.000000]   HighMem zone: 66990 pages, LIFO batch:15
[    0.000000] script_init enter!
[    0.000000] script_init exit!
[    0.000000] PERCPU: Embedded 8 pages/cpu @c148c000 s11968 r8192 d12608 u32768
[    0.000000] pcpu-alloc: s11968 r8192 d12608 u32768 alloc=8*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 259840
[    0.000000] Kernel command line: console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 cgroup_enable=memory swapaccount=1 panic=10 consoleblank=0 enforcing=0 loglevel=1
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] allocated 2097152 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Memory: 1024MB = 1024MB total
[    0.000000] Memory: 758584k/758584k available, 289992k reserved, 270336K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc096bf2c   (9616 kB)
[    0.000000]       .init : 0xc096c000 - 0xc09beec0   ( 332 kB)
[    0.000000]       .data : 0xc09c0000 - 0xc0a3a1d0   ( 489 kB)
[    0.000000]        .bss : 0xc0a3a984 - 0xc0b75bd0   (1261 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Additional per-CPU info printed with stalls.
[    0.000000] NR_IRQS:544
[    0.000000] Architected local timer running at 24.00MHz.
[    0.000000] Switching to timer-based delay loop
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[    0.000000] Console: colour dummy device 80x30
[    0.000000] console [tty1] enabled
[    0.000261] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000)
[    0.000285] pid_max: default: 32768 minimum: 301
[    0.000618] Mount-cache hash table entries: 512
[    0.001581] Initializing cgroup subsys cpuacct
[    0.001597] Initializing cgroup subsys memory
[    0.001645] Initializing cgroup subsys devices
[    0.001657] Initializing cgroup subsys freezer
[    0.001668] Initializing cgroup subsys blkio
[    0.001692] Initializing cgroup subsys perf_event
[    0.001775] CPU: Testing write buffer coherency: ok
[    0.001819] ftrace: allocating 25980 entries in 77 pages
[    0.030295] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.030313] [sunxi_smp_prepare_cpus] enter
[    0.030349] Setting up static identity map for 0x4069f800 - 0x4069f858
[    0.031283] CPU1: Booted secondary processor
[    0.031283] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.031416] CPU2: Booted secondary processor
[    0.031416] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.040478] CPU3: Booted secondary processor
[    0.040478] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.040599] Brought up 4 CPUs
[    0.040599] SMP: Total of 4 processors activated (19200.00 BogoMIPS).
[    0.040898] devtmpfs: initialized
[    0.050542] wakeup src cnt is : 2.
[    0.050555] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000
[    0.050566] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x0
[    0.050577] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40
[    0.050588] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000
[    0.050599] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x8
[    0.050609] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40
[    0.050621] sunxi pm init
[    0.050759] pinctrl core: initialized pinctrl subsystem
[    0.060792] NET: Registered protocol family 16
[    0.061566] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.061566] script_sysfs_init success
[    0.061566] sunxi_dump_init success
[    0.062447] gpiochip_add: registered GPIOs 0 to 383 on device: sunxi-pinctrl
[    0.063661] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver
[    0.063661] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.063661] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.063661] script config pll_video to 297 Mhz
[    0.063661] script config pll_de to 864 Mhz
[    0.063661] script config pll_ve to 402 Mhz
[    0.063661] sunxi_default_clk_init
[    0.063661] try to set pll6ahb1 to 200000000
[    0.063661] try to set ahb clk source to pll6ahb1
[    0.063661] set ahb clk source to pll6ahb1
[    0.063661] try to set ahb1 to 200000000
[    0.063661] try to set apb1 to 100000000
[    0.070227] bio: create slab <bio-0> at 0
[    0.070308] [ARISC] :sunxi-arisc driver v1.04
[    0.089902] [ARISC] :arisc version: [v0.1.58]
[    0.180144] [ARISC] :sunxi-arisc driver v1.04 startup succeeded
[    0.181749] SCSI subsystem initialized
[    0.181749] usbcore: registered new interface driver usbfs
[    0.181749] usbcore: registered new interface driver hub
[    0.181749] usbcore: registered new device driver usb
[    0.181749] twi_chan_cfg()340 - [twi0] has no twi_regulator.
[    0.181749] twi_chan_cfg()340 - [twi1] has no twi_regulator.
[    0.181749] twi_chan_cfg()340 - [twi2] has no twi_regulator.
[    0.181749] Linux video capture interface: v2.00
[    0.181749] Advanced Linux Sound Architecture Driver Version 1.0.25.
[    0.181749] cfg80211: Calling CRDA to update world regulatory domain
[    0.181782] Switching to clocksource arch_sys_counter
[    0.193930] FS-Cache: Loaded
[    0.194211] CacheFiles: Loaded
[    0.205540] NET: Registered protocol family 2
[    0.216889] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.217471] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.219232] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
[    0.220321] TCP: Hash tables configured (established 131072 bind 65536)
[    0.220333] TCP: reno registered
[    0.220347] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.220385] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.220742] NET: Registered protocol family 1
[    0.221117] RPC: Registered named UNIX socket transport module.
[    0.221129] RPC: Registered udp transport module.
[    0.221138] RPC: Registered tcp transport module.
[    0.221146] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.221335] Trying to unpack rootfs image as initramfs...
[    0.409712] Freeing initrd memory: 3064K
[    0.410108] hw perfevents: enabled with ARMv7 Cortex_A7 PMU driver, 5 counters available
[    0.410235] sunxi_reg_init enter
[    0.411162] audit: initializing netlink socket (disabled)
[    0.411213] type=2000 audit(0.410:1): initialized
[    0.412355] highmem bounce pool size: 64 pages
[    0.413251] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.413448] misc fatfs initialized
[    0.414171] NFS: Registering the id_resolver key type
[    0.414544] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.414558] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    0.415320] NTFS driver 2.1.30 [Flags: R/W].
[    0.415622] fuse init (API version 7.18)
[    0.416369] Btrfs loaded
[    0.416392] msgmni has been set to 1471
[    0.417705] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[    0.417726] io scheduler noop registered
[    0.417736] io scheduler deadline registered
[    0.417814] io scheduler cfq registered (default)
[    0.418217] [DISP]disp_module_init
[    0.418515] cmdline,init_disp=
[    0.418544] cmdline,disp=
[    0.426380] [DISP] Fb_map_kernel_logo,line:932:Fb_map_kernel_logo failed!
[    0.442795] Console: switching to colour frame buffer device 160x45
[    0.460142] [DISP]disp_module_init finish
[    0.460369] sw_uart_get_devinfo()1503 - uart0 has no uart_regulator.
[    0.460690] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[    0.460704] sw_uart_pm()890 - uart0 clk is already enable
[    0.461238] sunxi_cmatest_init enter
[    0.461276] sunxi_cmatest_init success
[    0.465394] brd: module loaded
[    0.469272] loop: module loaded
[    0.469552] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
[    0.469566] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator.
[    0.470188] spi spi0: master is unqueued, this is deprecated
[    0.470517] tun: Universal TUN/TAP device driver, 1.6
[    0.470527] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    0.471486] PPP generic driver version 2.4.2
[    0.471671] PPP BSD Compression module registered
[    0.471681] PPP Deflate Compression module registered
[    0.474421] PPP MPPE Compression module registered
[    0.474439] NET: Registered protocol family 24
[    0.474515] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.494614] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.494652] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1
[    0.495290] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000
[    0.510036] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00
[    0.510675] hub 1-0:1.0: USB hub found
[    0.510700] hub 1-0:1.0: 1 port detected
[    0.531075] sunxi-ehci sunxi-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.531105] sunxi-ehci sunxi-ehci.2: new USB bus registered, assigned bus number 2
[    0.531608] sunxi-ehci sunxi-ehci.2: irq 106, io mem 0xf1c1b000
[    0.550033] sunxi-ehci sunxi-ehci.2: USB 0.0 started, EHCI 1.00
[    0.550549] hub 2-0:1.0: USB hub found
[    0.550573] hub 2-0:1.0: 1 port detected
[    0.570927] sunxi-ehci sunxi-ehci.3: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.570956] sunxi-ehci sunxi-ehci.3: new USB bus registered, assigned bus number 3
[    0.571443] sunxi-ehci sunxi-ehci.3: irq 108, io mem 0xf1c1c000
[    0.590042] sunxi-ehci sunxi-ehci.3: USB 0.0 started, EHCI 1.00
[    0.590588] hub 3-0:1.0: USB hub found
[    0.590608] hub 3-0:1.0: 1 port detected
[    0.610978] sunxi-ehci sunxi-ehci.4: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.611007] sunxi-ehci sunxi-ehci.4: new USB bus registered, assigned bus number 4
[    0.611494] sunxi-ehci sunxi-ehci.4: irq 110, io mem 0xf1c1d000
[    0.630033] sunxi-ehci sunxi-ehci.4: USB 0.0 started, EHCI 1.00
[    0.630048] ehci_irq: highspeed device connect
[    0.630591] hub 4-0:1.0: USB hub found
[    0.630616] hub 4-0:1.0: 1 port detected
[    0.630991] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.651062] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    0.651090] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 5
[    0.651125] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400
[    0.714551] hub 5-0:1.0: USB hub found
[    0.714572] hub 5-0:1.0: 1 port detected
[    0.734949] sunxi-ohci sunxi-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    0.734977] sunxi-ohci sunxi-ohci.2: new USB bus registered, assigned bus number 6
[    0.735010] sunxi-ohci sunxi-ohci.2: irq 107, io mem 0xf1c1b400
[    0.794582] hub 6-0:1.0: USB hub found
[    0.794602] hub 6-0:1.0: 1 port detected
[    0.814981] sunxi-ohci sunxi-ohci.3: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    0.815010] sunxi-ohci sunxi-ohci.3: new USB bus registered, assigned bus number 7
[    0.815044] sunxi-ohci sunxi-ohci.3: irq 109, io mem 0xf1c1c400
[    0.874571] hub 7-0:1.0: USB hub found
[    0.874591] hub 7-0:1.0: 1 port detected
[    0.894980] sunxi-ohci sunxi-ohci.4: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    0.895008] sunxi-ohci sunxi-ohci.4: new USB bus registered, assigned bus number 8
[    0.895039] sunxi-ohci sunxi-ohci.4: irq 111, io mem 0xf1c1d400
[    0.950044] usb 4-1: new high-speed USB device number 2 using sunxi-ehci
[    0.954518] hub 8-0:1.0: USB hub found
[    0.954545] hub 8-0:1.0: 1 port detected
[    0.954877] Initializing USB Mass Storage driver...
[    0.955110] usbcore: registered new interface driver usb-storage
[    0.955121] USB Mass Storage support registered.
[    0.955180] usbcore: registered new interface driver ums-alauda
[    0.955230] usbcore: registered new interface driver ums-cypress
[    0.955279] usbcore: registered new interface driver ums-datafab
[    0.955328] usbcore: registered new interface driver ums_eneub6250
[    0.955377] usbcore: registered new interface driver ums-freecom
[    0.955424] usbcore: registered new interface driver ums-isd200
[    0.955470] usbcore: registered new interface driver ums-jumpshot
[    0.955518] usbcore: registered new interface driver ums-karma
[    0.955572] usbcore: registered new interface driver ums-onetouch
[    0.955637] usbcore: registered new interface driver ums-realtek
[    0.955688] usbcore: registered new interface driver ums-sddr09
[    0.955737] usbcore: registered new interface driver ums-sddr55
[    0.955783] usbcore: registered new interface driver ums-usbat
[    0.956085] file system registered
[    0.957723] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    0.957739] android_usb gadget: Number of LUNs=3
[    0.957751]  lun0: LUN: removable file: (no medium)
[    0.957761]  lun1: LUN: removable file: (no medium)
[    0.957771]  lun2: LUN: removable file: (no medium)
[    0.958116] android_usb gadget: android_usb ready
[    0.958335]  uinput result 0 , vmouse_init
[    0.958954] mousedev: PS/2 mouse device common for all mice
[    0.959198] sunxikbd_init failed.
[    0.959953] ls_fetch_sysconfig_para: type err  device_used = -1073060236.
[    0.959965] =========script_get_err============
[    0.959973] ltr_init: ls_fetch_sysconfig_para err.
[    0.960616] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0
[    0.960670] i2c /dev entries driver
[    0.961066] IR RC5(x) protocol handler initialized
[    0.961194] sunxi cedar version 0.1
[    0.961237] [cedar]: install start!!!
[    0.961432] [cedar]: install end!!!
[    0.961675] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x18)
[    0.961842] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x19)
[    0.962006] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x1a)
[    0.962170] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x29)
[    0.962334] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2a)
[    0.962498] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2b)
[    0.962662] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4c)
[    0.962825] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4d)
[    0.962988] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4e)
[    0.963184] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x18)
[    0.963375] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x19)
[    0.963567] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1a)
[    0.963758] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x29)
[    0.963949] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2a)
[    0.964140] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2b)
[    0.964331] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4c)
[    0.964522] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4d)
[    0.964713] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4e)
[    0.964727] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0
[    0.964900] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->start 0x01c20ca0, res->end 0x01c20cbf
[    0.965041] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0)
[    0.965056] wdt_enable, write reg 0xf1c20cb8 val 0x00000000
[    0.965067] timeout_to_interv, line 167
[    0.965076] interv_to_timeout, line 189
[    0.965087] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual timeout 16 sec
[    0.965512] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[    0.965611] calibrat: max_cpufreq 1200Mhz Type 0!
[    0.966047] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.111 2015-4-13 15:24) Compiled in May 31 2016 at 18:59:51
[    0.966082] [mmc]: get mmc0's sdc_power is null!
[    0.966109] [mmc]: get mmc1's sdc_power is null!
[    0.966118] [mmc]: get mmc1's 2xmode ok, val = 1
[    0.966127] [mmc]: get mmc1's ddrmode ok, val = 1
[    0.966143] [mmc]: MMC host used card: 0x3, boot card: 0x1, io_card 2
[    0.967086] [mmc]: sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    0.968199] [mmc]: sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    0.968740] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    0.969741] [mmc]: sdc0 power_supply is null
[    0.971584] no blue_led, ignore it!
[    0.971813] Registered led device: red_led
[    0.971916] Registered led device: green_led
[    0.971932] no led_0, ignore it!
[    0.971940] no led_1, ignore it!
[    0.971947] no led_2, ignore it!
[    0.971954] no led_3, ignore it!
[    0.971961] no led_4, ignore it!
[    0.971968] no led_5, ignore it!
[    0.971975] no led_6, ignore it!
[    0.971982] no led_7, ignore it!
[    0.972797] usbcore: registered new interface driver usbhid
[    0.972806] usbhid: USB HID core driver
[    0.976974] asoc: sndcodec <-> sunxi-codec mapping ok
[    0.977842] [DAUDIO]sunxi-daudio cannot find any using configuration for controllers, return directly!
[    0.978035] [I2S]snddaudio cannot find any using configuration for controllers, return directly!
[    0.978048] [DAUDIO0] driver not init,just return.
[    0.981538] asoc: sndhdmi <-> sunxi-hdmiaudio.0 mapping ok
[    0.982564] oprofile: using arm/armv7-ca7
[    0.982757] u32 classifier
[    0.982767]     Actions configured
[    0.982955] IPv4 over IPv4 tunneling driver
[    0.983613] TCP: bic registered
[    0.983624] TCP: cubic registered
[    0.983631] TCP: westwood registered
[    0.983638] TCP: highspeed registered
[    0.983646] TCP: hybla registered
[    0.983653] TCP: htcp registered
[    0.983660] TCP: vegas registered
[    0.983668] TCP: veno registered
[    0.983675] TCP: scalable registered
[    0.983683] TCP: lp registered
[    0.983690] TCP: yeah registered
[    0.983697] TCP: illinois registered
[    0.983705] Initializing XFRM netlink socket
[    0.983956] NET: Registered protocol family 10
[    0.985105] NET: Registered protocol family 17
[    0.985136] NET: Registered protocol family 15
[    0.985186] Registering the dns_resolver key type
[    0.985485] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.985507] ThumbEE CPU extension supported.
[    0.985529] Registering SWP/SWPB emulation handler
[    0.986123] registered taskstats version 1
[    0.986593] cmdline,disp=
[    0.986907] [HDMI] power vcc-hdmi-18
[    0.990063] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.011725] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.014221] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.017642] ths_fetch_sysconfig_para: type err  device_used = 1.
[    1.019210] CPU Budget:Register notifier
[    1.019243] CPU Budget:register Success
[    1.019257] sunxi-budget-cooling sunxi-budget-cooling: Cooling device registered: thermal-budget-0
[    1.019573] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.022400] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.022618] [rf_pm]: module power0 name vcc-wifi-33
[    1.022632] [rf_pm]: Did not config module_power1 in sys_config
[    1.022642] [rf_pm]: Did not config module_power2 in sys_config
[    1.022652] [rf_pm]: Did not config module_power3 in sys_config
[    1.022662] [rf_pm]: mod has no chip_en gpio
[    1.022670] [rf_pm]: failed to fetch lpo_use_apclk
[    1.022678] [rf_pm]: regulator on.
[    1.022688] [wifi_pm]: no wifi used in configuration
[    1.022698] [rfkill]: init no bt used in configuration
[    1.022706] ALSA device list:
[    1.022713]   #0: audiocodec
[    1.022720]   #1: sndhdmi
[    1.023502] Freeing init memory: 328K
[    1.024952] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.041636] [mmc]: sdc0 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.043170] [mmc]: sdc0 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    1.043265] [mmc]: sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    1.043406] [mmc]: sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B
[    1.043493] mmc0: new high speed SDHC card at address 0007
[    1.044008] mmcblk0: mmc0:0007 SD8GB 7.42 GiB
[    1.045472]  mmcblk0: p1
[    1.046045] mmcblk mmc0:0007: Card claimed for testing.
[    1.046065] mmc0:0007: SD8GB 7.42 GiB
[    1.046111] *******************sd init ok*******************
[    1.068962] systemd-udevd[100]: starting version 215
[    1.620051] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device0, type=4, mode=5
[    2.499609] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[    3.730539] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[    3.731111] systemd[1]: Detected architecture 'arm'.
[    3.746869] systemd[1]: Set hostname to <orangepipc>.
[    4.085410] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[    4.087840] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[    4.088184] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    4.088256] systemd[1]: Expecting device dev-ttySAC2.device...
[    4.088777] systemd[1]: Starting Remote File Systems (Pre).
[    4.089115] systemd[1]: Reached target Remote File Systems (Pre).
[    4.089203] systemd[1]: Starting Encrypted Volumes.
[    4.089507] systemd[1]: Reached target Encrypted Volumes.
[    4.089583] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[    4.089767] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    4.089821] systemd[1]: Starting Paths.
[    4.090186] systemd[1]: Reached target Paths.
[    4.090306] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[    4.091138] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    4.091219] systemd[1]: Starting Root Slice.
[    4.091589] systemd[1]: Created slice Root Slice.
[    4.091645] systemd[1]: Starting User and Session Slice.
[    4.092078] systemd[1]: Created slice User and Session Slice.
[    4.092134] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[    4.092622] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    4.092678] systemd[1]: Starting Delayed Shutdown Socket.
[    4.093067] systemd[1]: Listening on Delayed Shutdown Socket.
[    4.093123] systemd[1]: Starting Journal Socket (/dev/log).
[    4.093537] systemd[1]: Listening on Journal Socket (/dev/log).
[    4.093612] systemd[1]: Starting udev Control Socket.
[    4.093978] systemd[1]: Listening on udev Control Socket.
[    4.094046] systemd[1]: Starting udev Kernel Socket.
[    4.094382] systemd[1]: Listening on udev Kernel Socket.
[    4.094461] systemd[1]: Starting Journal Socket.
[    4.094843] systemd[1]: Listening on Journal Socket.
[    4.094952] systemd[1]: Starting System Slice.
[    4.095366] systemd[1]: Created slice System Slice.
[    4.095468] systemd[1]: Started File System Check on Root Device.
[    4.095516] systemd[1]: Starting system-getty.slice.
[    4.096014] systemd[1]: Created slice system-getty.slice.
[    4.096068] systemd[1]: Starting system-serial\x2dgetty.slice.
[    4.096542] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    4.096659] systemd[1]: Starting Increase datagram queue length...
[    4.170720] systemd[1]: Starting Restore / save the current clock...
[    4.270771] systemd[1]: Starting udev Coldplug all Devices...
[    4.320790] systemd[1]: Mounting POSIX Message Queue File System...
[    4.367100] systemd[1]: Starting Load Kernel Modules...
[    4.441152] systemd[1]: Mounting Debug File System...
[    4.550692] systemd[1]: Mounted Huge Pages File System.
[    4.560196] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    4.561739] [mmc]: sdc1 power_supply is null
[    4.570164] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    4.580070] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    4.603243] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    4.605729] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    4.614153] [mmc]: sdc1 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    4.615077] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    4.615188] [mmc]: sdc1 power_supply is null
[    4.617763] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    4.619287] [mmc]: sdc1 power_supply is null
[    4.640034] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    4.643246] systemd[1]: Started Set Up Additional Binary Formats.
[    4.643363] systemd[1]: Starting LSB: Set keymap...
[    4.660180] [wifi_pm]: set wl_reg_on 1 !
[    4.663773] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    4.666420] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    4.677268] [mmc]: sdc1 set ios: clk 300000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    4.678472] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    4.678581] [mmc]: sdc1 power_supply is null
[    4.681157] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    4.682684] [mmc]: sdc1 power_supply is null
[    4.700042] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    4.720540] systemd[1]: Starting Slices.
[    4.720987] systemd[1]: Reached target Slices.
[    4.723249] systemd[1]: Mounted Debug File System.
[    4.723801] systemd[1]: Mounted POSIX Message Queue File System.
[    4.724865] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    4.727779] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    4.743482] [mmc]: sdc1 set ios: clk 200000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    4.745246] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    4.745355] [mmc]: sdc1 power_supply is null
[    4.747933] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    4.749459] [mmc]: sdc1 power_supply is null
[    4.770032] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    4.795841] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    4.798973] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    4.800513] systemd[1]: Started Increase datagram queue length.
[    4.819484] [mmc]: sdc1 set ios: clk 150000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    4.821822] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    4.821929] [mmc]: sdc1 power_supply is null
[    4.893937] systemd[1]: Started Restore / save the current clock.
[    5.135134] systemd[1]: Started Load Kernel Modules.
[    5.185137] systemd[1]: Started Create list of required static device nodes for the current kernel.
[    5.234915] systemd[1]: Started LSB: Set keymap.
[    5.330135] systemd[1]: Started udev Coldplug all Devices.
[    5.334045] systemd[1]: Time has been changed
[    5.335018] systemd[1]: Starting Create Static Device Nodes in /dev...
[    5.451982] systemd[1]: Mounted Configuration File System.
[    5.452219] systemd[1]: Starting Apply Kernel Variables...
[    5.570846] systemd[1]: Mounting FUSE Control File System...
[    5.640493] systemd[1]: Starting Syslog Socket.
[    5.645626] systemd[1]: Listening on Syslog Socket.
[    5.645783] systemd[1]: Starting Journal Service...
[    5.738518] systemd[1]: Started Journal Service.
[    6.056200] systemd-udevd[180]: starting version 215
[    6.767316] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[    7.058080] Adding 131068k swap on /var/swap.  Priority:-1 extents:3 across:2286616k SS
[    8.295688] systemd-journald[179]: Received request to flush runtime journal from PID 1
[    8.616949] gmac0: probed
[    8.617351] gmac0 gmac0: eth0: eth0: PHY ID 00441400 at 0 IRQ poll (gmac0-0:00)
[   12.610272] PHY: gmac0-0:00 - Link is Up - 100/Full
[   19.330060] eth0: no IPv6 routers present
[   24.522651] [DISP] disp_ioctl,line:1584:para err in disp_ioctl, cmd = 0x0,screen id = 65536
[   24.552334] UMP: UMP device driver  loaded
[   24.570330] mali clk: 600 MHz
[   24.571294] mali clk: 600 MHz
[   24.575368] Mali: Mali device driver loaded
[   24.607093] [drm] Initialized drm 1.1.0 20060810
[   24.613708] Mali DRM initialize, driver name: mali_drm, version 2.1
[   24.614263] [drm] Initialized mali_drm 2.1.1 20101111 on minor 0
[   24.614321] Mali DRM initialize, driver name: mali_drm, version 2.1
[   24.614639] [drm] Initialized mali_drm 2.1.1 20101111 on minor 1
[   25.021094] vmouse_input_dev_open
Edited by zador.blood.stained
Added spoiler tags
unfortunately I'm having the exactly same problem. Used another dongle before, but I was tired of problems compiling for armbian every apt-get upgrade, specially since it is a headless machine and usually accessed by ssh; then purchased the most common dongle for RPi and other boards, these Ralink ones, just to avoid having these problems, but no luck these time...
the link to the log:
http://sprunge.us/KLPb
Try 'depmod' .
depmod helped. I didn't know I also had to use it, even if I didn't compile any driver (only installed the ralink firmware package).
Thanks!
(should depmod run with the upgrade packages' scripts? like the headers compilation?)
No luck, I've tried practically every setting....  my key appears to be HEX I'm not sure if that's coincidence or not, my wifi is wpa2, should i be using wpa 1/2 hex ?
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
