Skip to content
View in the app
Armbian Community Forums
Gpio questions on useage
Featured Replies
I am looking for some recommendations for using the Gpio on the opi PC ( with uname -r 5.7.15-sunxi )
The project is to open and close a glass house door using a temperature probe ( ds18B20 ) and a relay control board ( opto coupled with active low input ).
Later I will add automatic watering relay board.
The pins I would like to use are
Inputs
PC0     used for ds18B20   (SPI0_MOSI)    because it is an Input
PC4    Door closed switch         Internal pullup
PC7    Door is fully open switch     Internal pullup
PC3     Input to be used later(SPI0_CS) Innternal pullup
Outputs
PD14            output  MC  motor close door
PC1     (SPI0_MISO)    output  MC  motor close door    because it is an output
Proposed outputs to be used later
PA0    (UART2_TX/JTAG_MS/PA_EINT0)
PA11    (TWI0_SCK/DI_TX/PA_EINT11)
PA13 (SPI1_CS/UART3_TX/PA_EINT13)
PG6    (UART1_TX/PG_EINT6)
Data  from Allwinner H3 Datasheet
I am using these commands to set inputs
echo 71 > /sys/class/gpio/export
echo "in" > /sys/class/gpio/gpio71/direction
My questions are:
1) what do you think of the chosen pins?
2) Do I need to do anything to configure inputs to use pullups?
3) How can I set output pins to start out as high so as not to trigger the relay on startup?
    I am trying to use  for outup
                  echo 110 > /sys/class/gpio/export                #    pin12    PD14    MCD o/p relay    110
                  echo "out" > /sys/class/gpio/gpio110/direction
                  echo 1 > /sys/class/gpio/gpio110/value
which causes the relay to turn ON then OFF
Thanks for all of your advice
Dave
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
