Skip to content
View in the app
Armbian Community Forums
N2+ failing to boot multiple times
Featured Replies
So, I've noticed there were some updates available, so decided to do so, now running 20.08.7 Focal / 5.8.13 kernel.
Now, I did run the nand-sata-install when I first installed armbian a month ago to an external SSD and all's working perfectly. The thing is, a couple of weeks ago, even after this latest update and rebooting, the sbc won't boot up, I had to pull the plug and back about 20 times for it to boot. So this is what I found running dmesg.
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.8.13-meson64 (root@xeon) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #20.08.6 SMP PREEMPT Thu Oct 1 18:51:27 CEST 2020
[    0.000000] Machine model: Hardkernel ODROID-N2Plus
[    0.000000] efi: UEFI not found.
[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff]
[    0.000000] NUMA: NODE_DATA [mem 0xb5033100-0xb5034fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ed7fffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
[    0.000000]   node   0: [mem 0x0000000005300000-0x00000000ed7fffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff]
Specifically [    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
Is there anything I can do to fix this? I dread whenever I need to reboot due to having to go around doing this.
I've also noticed the hwclock isn't working properly?
sptz@odroidn2:~$ hwclock --test -D
hwclock: use --verbose, --debug has been deprecated.
hwclock from util-linux 2.34
System Time: 1601811651.679131
Trying to open: /dev/rtc0
No usable clock interface found.
hwclock: Cannot access the Hardware Clock via any known method.
If you are not a kernel hacker, migrating to stock legacy kernel , wait that its fixed, downgrade kernel to last known to work version -> armbian-config -> system -> alternative kernels + freezing kernel updates at that kernel (also in armbian-config) ...
If you want to have modern kernel, this is a very small price to pay. Porting drivers from a kernel where support for hardware was developed (private hardkernel kernel 4.9.y in this case) takes years, costs millions. Which is why support comes this way.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
