October 18, 20205 yr Solution I've configured and connected to a wifi network just fine, but I want to change the config non-interactively. The config isn't in /etc/wpa_supplicant/wpa_supplicant.conf or anywhere else I'd expect, and https://github.com/armbian/config/ only mentions hostapd. Where's the config stored? Edit: /etc/NetworkManager/system-connections/[my SSID]
October 18, 20205 yr From what I read in the source I assume the whole wifi stuff is handled via hostapd. Did you take a look at its config files?
October 23, 20205 yr Author On 10/18/2020 at 4:48 PM, Werner said: From what I read in the source I assume the whole wifi stuff is handled via hostapd. Did you take a look at its config files? Yes, and no, hostapd only handles access points, not connecting to wifi as a client.
September 29, 20233 yr Its stored in the following directory /etc/NetworkManager/system-connections good luck!
