Skip to content
View in the app
Armbian Community Forums
Hardware PWM on Orange Pi Zero H2+ updates very slowly with script
Featured Replies
I'm running the latest 5.10.21-sunxi kernel. I figured out how to use the PWM pin with the help of this post.
I have an LED connected to the PWM pin and when I run for example:
sudo sh -c "echo 250 > /sys/class/pwm/pwmchip0/pwm0/duty_cycle"
the LED updates instantly. But when I try to fade the LED with a script, the LED always takes 6 seconds to update.
This is the script:
#!/bin/bash
#Export PWM channel for user control.
sh -c "echo 0 > /sys/class/pwm/pwmchip0/export"
#Select the period of PWM signal. Value is in nanoseconds.
sh -c "echo 500 > /sys/class/pwm/pwmchip0/pwm0/period"
#Change the polarity of the PWM signal.
#The polarity can only be changed if the PWM is not enabled.
sh -c "echo "normal" > /sys/class/pwm/pwmchip0/pwm0/polarity"
#Enable the PWM signal.
sh -c "echo 1 > /sys/class/pwm/pwmchip0/pwm0/enable"
for i in {0..500}
do
        sh -c "echo $i > /sys/class/pwm/pwmchip0/pwm0/duty_cycle"
        cat /sys/class/pwm/pwmchip0/pwm0/duty_cycle #Just for debugging
        sleep 0.1
done
#Disable the PWM signal.
sh -c "echo 0 > /sys/class/pwm/pwmchip0/pwm0/enable"
#UnExport PWM channel for user control.
sh -c "echo 0 > /sys/class/pwm/pwmchip0/unexport"
I hope someone can help me. It's so hard to find any resources for this sort of thing.
Solved by Zeko9381
  • Author
  • Solution
Ok, this was a pretty dumb post. This example that I found seems to be incorrect. The value for the period isn't in nanoseconds, but in picoseconds, so the correct value would actually be 500000. 500 picosecond period would mean a frequency of 2 MHz, which is way too high. The problem wasn't that the LED took too long to update, but that the resolution at this frequency was way too low.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
