Skip to content
View in the app
Armbian Community Forums
Boot from SSD using Hardkernel's Odroid HC4
Featured Replies
My current HC4-setup consists of 1 SSD and 1 HDD. The SSD contains the most recent Armbian-image (Buster-based) (https://redirect.armbian.com/odroidhc4/Buster_current).
Long story short: it won't boot from SSD, and Google tells me it is because Armbian is not compatible with Petiboot. Armbian suggests the following solution:
"Important: To be able to boot clean Armbian mainline based u-boot / kernel experiences, you need to remove incompatible Petitboot loader that is shipped with the board. From the Petitboot, go for “Exit to shell” and these commands to remove the Petitboot:"
# flash_eraseall /dev/mtd0
# flash_eraseall /dev/mtd1
# flash_eraseall /dev/mtd2
# flash_eraseall /dev/mtd3
"This will make your SPI flash memory empty and would start from SD on next boot."
However, it doesn't mention whether this works for booting from an SSD. Does it? And if not, is there a possibility of booting Armbian from an SSD without using an SD-card?
Thanks in advance!
P.S. I found the following (unresolved) related question: https://www.reddit.com/r/ODroid/comments/moxxhl/uboot_from_sata_on_hc4/
  • Author
Thanks for your response. Thus I could flash a separate boot loader to an SD-card? Which boot loader do I need?
Boot from SSD without SD card is currently not supported on HC4. However, it is easy to have only the boot loader on SD card (as @Werner stated above):
- flash armbian image to SD Card
- erase petitboot as stated above
- boot armbian from SD Card
- run nand-sata-install within armbian
after this
- only the boot loader rests on SD card (i.e. you need the SD card plugged in for it to be able to boot) - but no I/O on SD card after boot loader
- OS root partition (and entire system) runs from SSD
- any update updates boot loader and kernel where they actually reside - so no special precautions needed (despite the usual "update may break something")
I am running on this setup and it works like a charm for me.
Hope that helps
Green Daddy
  • Author
Good to see so many responses (indicates an active community :))
@Green Daddythanks for your step-by-step-guide! My HC4 is happy with the provided solution.
Hi
Which image do you both use? I've just booted Armbian_21.05.4_Odroidhc4_buster_current_5.10.43.img and and Linux believe there is no link on eth0, it's what ethtool reports and I cannot access the network.
BTW, I didn't erase Petitboot, just forced booting from SD-card by pressing "reset" button during power-on.
When booted into Petitboot ethernet works but I didn't manage to istall an OS. I see (snooping on the net) my HC4 downloading the netboot-odroidhc4.cfg file but nothing happens.
Quite dissapointed with my new toy :-(
Regards,
Chris
Those are development boards  ;) But I think we are close to getting stable support based on clean open source. We want to get rid of vendors proprietary solutions as soon as possible. Troubles as you have are the price that needs to be paid. Boot from SPI is also under development - not sure if it will be done before this major release.
We are just about (this month) to push out major update, where many things for this board was fixed. Try this image:
https://imola.armbian.com/dl/odroidc4/nightly/Armbian_21.08.0-trunk.114_Odroidc4_hirsute_edge_5.13.8.img.xz
It works perfectly on my C4:
  ___      _           _     _    ____ _  _
 / _ \  __| |_ __ ___ (_) __| |  / ___| || |
| | | |/ _` | '__/ _ \| |/ _` | | |   | || |_
| |_| | (_| | | | (_) | | (_| | | |___|__   _|
 \___/ \__,_|_|  \___/|_|\__,_|  \____|  |_|
Welcome to Armbian 21.08.0-trunk.113 Hirsute with Linux 5.13.8-meson64
No end-user support: untested automated build
System load:   7%           	Up time:       1 min
Memory usage:  4% of 3.73G  	IP:	       10.0.30.121
CPU temp:      38°C           	Usage of /:    6% of 29G
[ 0 security updates available, 7 updates total: apt upgrade ]
Last check: 2021-08-07 20:17
[ General system configuration (beta): armbian-config ]
Logs: http://ix.io/3vhZ
As for "Those are development boards" I will comment later ;-)
The imola image doesn't boot on my hc4. Nothing on HDMI attached monitor and on the serial console I get such output:
LOOP:35;SPINOR:0;CHK:1F;EMMC:800;NAND:81;SD?:0;SD:0;READ:0;CHK:1F;USB:8;
again and again.
Ooops, I see a small difference, your c4 != my hc4, right?
Regards,
Chris
Oh, yes. But they are not that different and it should boot. @rpardini was trying to bring things together and this is the last addition:
https://github.com/armbian/build/commit/13329ebcd0f3f0270c7813e33599fa75d939bb24#diff-b79606fb3afea5bd1609ed40b622142f1c98125abcfe89a76a661b0e8e343910
I don't have HC4, only C4.
There is an image for HC4 as well, but it would be good that someone else test this too. So we can be sure it boots:
https://imola.armbian.com/dl/odroidhc4/nightly/
Armbian_21.08.0-trunk.114_Odroidhc4_hirsute_edge_5.13.8.img doesn't boot.
On console theese:
SM1:BL:511f6b:81ca2f;FEAT:A0F83180:20282000;POC:A;RCY:0;SPINOR:0;CHK:1F;EMMC:800;
NAND:81;SD?:0;SD:0;READ:0;CHK:1F;USB:8;LOOP:1;SPINOR:0;CHK:1F;EMMC:800;
NAND:81;SD?:0;SD:0;READ:0;CHK:1F;USB:8;LOOP:2;SPINOR:0;CHK:1F;EMMC:800;
On console theese:
I also tried - it seems we do have an issue. Investigating ...
This afternoon booted Armbian_21.08.0-trunk.116_Odroidhc4_hirsute_edge_5.13.9.img on  my hc4. Everything looks OK :-)
As for the "Those are development boards ;)", one thing I don't understand: again and again there are new SBC's popping up designed(?) to run Linux but they cannot cope with main-stream or use components not well supported. OrangePi-PC few years ago, desaster. TinkerBoard & TinkerOS.... "Recently" OrangePi-zero & onboard WiFi. Now Odroid-hc4 with broken Petitboot and one man "support".
Lucky us, there is Armbian! :-)
Time to login to PayPal again, thank you very much for your efforts!
Regards,
Chris
BTW, I cannot find linux-headers-5.13.9-meson64. Need them to build ZFS modules.
Where are they hiding?
Edit: I will start a new thread for this. Sorry for hijacking this one..
Hello! Hopefully I've found the right place to ask a question and very grateful in advance for any attention and/or support.
I've bought Odroid HC4 and 2x4TB HDDs to create my own NAS and store my media there in RAID 1 manner + potentially set up a cloud via "NextCloud" for 24/7 access + upload - that is a dream :)
As of now, I've installed Debian 11 bullseye and OMV using this Youtube video: https://youtu.be/6YWZ5hFmVII?si=4C0ImjExexgWBilk
The concern I have is whether it is OK to have my OS on SD card, or is it recommended to move it to HDD using the method described:
In case it is better to do so, is there a chance you can advise some resources on how to execute each of the steps above?
Again, I am very grateful in advance for your time and support. In case I am addressing this incorrectly - my apologies.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
