Skip to content
View in the app
Armbian Community Forums
Compile Device Tree Overlay
Featured Replies
Hi,
I use kernel version 4.19.62-sunxi on my Orange Pi One and I want compile the following devide tree overlay:
/dts-v1/;
/plugin/;
	compatible = "allwinner,sun4i-a10", "allwinner,sun7i-a20", "allwinner,sun8i-h3", "allwinner,sun50i-a64", "allwinner,sun50i-h5";
	fragment@0 {
		target = <&pio>;
		__overlay__ {
			gpio_button_0: gpio_button_0 {
				pins = "PA20";
				function = "gpio_in";
				bias-pull-up;
	fragment@1 {
		target-path = "/";
		__overlay__ {
			gpio-keys-user {
				compatible = "gpio-keys";
				pinctrl-names = "default";
				pinctrl-0 = <&gpio_button_0>;
				power_button {
					label = "GPIO Key Power";
					linux,code = <KEY_POWER>;
					gpios = <&pio 0 20 GPIO_ACTIVE_LOW>;
dtc -I dts -O dtb -o overlay-user/test.dtbo overlay-user/gpio-poweroff.dts
But the DTC outputs the following error:
Error: overlay-user/gpio-poweroff.dts:2.2-8 syntax error
FATAL ERROR: Unable to parse input tree
What is wrong with this overlay?
Solved by kampi
These two lines. When compiling outside of the kernel source, constants like GPIO_ACTIVE_LOW don't get resolved because they don't have the kernel headers included in the compilation path.
If you have the linux kernel sources downloaded, a simple grep will tell you what they're supposed to be.
tparys@wander:linux/include/dt-bindings$ grep -r GPIO_ACTIVE_LOW .
./gpio/gpio.h:#define GPIO_ACTIVE_LOW 1
I'd also check that KEY_POWER is correct. That's not part of the 5.10 mainline, as far as I see.
In the future, just comment out parts of your dtc overlay until it compiles, and add parts back in until it breaks. Should narrow your problems down pretty quick.
  • Author
Hi,
sorry, but this doesn´t solve the problem. I reduce the overlay to
/dts-v1/;
/plugin/;
	fragment@0 {
		target = <&pio>;
		__overlay__ {
				pins = "PA20";
				bias-pull-up;
and I still have the same problem.
  • Author
I can compile the fragment on my Raspberry Pi with DT 1.4.7, so there is definitely an issue with the version. How can I update the DTC on my OrangePi? Using apt doesn´t work, because I have the current version already.
1.5.1-1 is current as of Ubuntu Focal. Perhaps a version difference in Debian, or an outdated install?
The output of "armbianmonitor -u" might help.
  • Author
vor 2 Stunden schrieb tparys:
mmh the command doesn´t output an URL.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
