Skip to content
View in the app
Armbian Community Forums
uboot help/issue
Featured Replies
hello,
what exactly has to be done / how if I want to change a roofs partition for uboot?  I can see its written inside these two files... but i cant see how to change that ... if i can directly edit these two files or something has to be executed...
armbianEnv.txt
boot.scr
thanks
@phier - boot.scr is reading and evaluating armbianEnv.txt - so armbianEnv.txt it the proper file to change it
good luck and best wishes - hexdump
  • Author
@hexdump so i do not need to configure / compile anything? all the control of uboot is done via that armbianEnv.txt - ie i only edit that file and thats it? thanks
@hexdump it doesnt work at all.
can someone advice here? thanks
@phier i it would be good if you would write some more details - otherwise its hard to help - for instance what system and what image you are using and what exactly you want to adjust/change ...
  • Author
@hexdump i installed latest ubuntu - armbian on sd card;
then i shrinked original partition rootfs; created now one; copied data from shrinked to the new one. And i want to boot from that new one.
ie if sd card was
sdf1
now its
sdf1 (old rootfs)
sdf2 (new rootfs)
And i want make uboot boot from sdf2
thanks
i think
boot/boot.scr has to be also updated ?
setenv devnum "0"
setenv rootdev "/dev/mmcblk${devnum}p1"
i believe uboot has to be somehow recompiled to point to /dev/mmcblk0p2 instead of /dev/mmcblk0p1
  • Author
uboot reads /boot/armbianEnv.txt & kernel images from the first partition marked as bootable (fdisk). Rootfs can be changed by updating armbianEnv.txt (on the first bootable partition) rootdev=UUID to boot from any partition.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
