Skip to content
View in the app
Armbian Community Forums
no wlan after clean install on bananapi m2plus
Featured Replies
Hi, not sure if this is the right place to ask, but I just dug up an old banana pi m2plus (with on board wifi) and flashed the latest Armbian_21.08.1_Bananapim2plus_bullseye_current_5.10.60 on a class 10 samsung evo micro sd. When booting for the first time I had a monitor, keyboard and LAN attached and successfully set up users with the wizard and apt upgrade the system.
Now I tried to set up wifi with "nmtui-connect SSID " after this guide:  https://docs.armbian.com/User-Guide_Getting-Started/
where SSID is the SSID of my network, but I get "No such connection 'SSID' " and I can only confirm.
If I open the networkmanager with it looks like this:
                            │ │Wired                 ↑           │ <Deactivate> │
                            │ │ * Wired connection 1  ▒ │              │
                            │ │                       ↓                │ <Quit>
$ sudo iwconfig
lo        no wireless extensions.
eth0      no wireless extensions.
wlan0     IEEE 802.11  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated   Tx-Power=31 dBm
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Encryption key:off
          Power Management:off
I reflashed the image with the same result.
sudo armbianmonitor -u
System diagnosis information will now be uploaded to http://ix.io/3G4v
Could it be a hardware problem?
Thankful for any suggestions on how to investigate.
Solved by arneee
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
