Skip to content
View in the app
Armbian Community Forums
[Pull Request] - [bootenv/rockchip] Force cgroup v1 usage
Featured Replies
Description
This commit forces cgroup v1 usage as a workaround for docker / runc BPF issues until a proper fix is submitted
Context
Docker 20.10+ cannot run on our Asus Tinkerboard, it throws BPF related errors (Like opencontainers/runc#2959 , especially this comment). I tried a lot of armbian flavors (focal, jammy, bullseye + current, edge and legacy kernels), and even building an image with CONFIG_BPF_SYSCALL=y as suggested by this comment but it didn't fix the issue. The only thing that fixed docker was to add extraargs=systemd.unified_cgroup_hierarchy=0 to /boot/armbianEnv.txt.
Until someone else does a proper fix to make cgroup v2 working, I suggest downgrading to cgroup v1 with this extraarg.
How Has This Been Tested?
  • [x] Tested on Asus Tinkerboard with latest 5.15 stable kernel from apt repository.
  • [ ] :x: NOT tested with edge and legacy kernels (Sorry I had to quickly put the machine into production and didn't have time to test other kernels)
Checklist:
  • [x] I have commented my code, particularly in hard-to-understand areas
  • [ ] I have made corresponding changes to the documentation => Does it need a documentation change ?
  • [x] Any dependent changes have been merged and published in downstream modules
View the full article
Great thanks for the workaround it was getting 2  RK boxes working OK with latest HA !!
Only the Systemd Journal issues left to fixig if its possible.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
