Skip to content
View in the app
Armbian Community Forums
systemd-journald and full disk /var/log after logrotate
Featured Replies
  I have problem with full disk /var/log and to problem is with systemd-journald. I can't understand, how it works.
  •   armbian-truncate-logs works fine. When is /var/log more than 75% full, the script truncates a log and files are copied to disk /var/log.hdd -> no problem here
  • before midnight is my /var/log 40% full
  • after midnight is my /var/log 100% full
  When I was investigating, where the problem was, I found that /var/log.hdd was bigger than the size of my partition /var/log.
  The biggest folder is /var/log.hdd/journald
 There are so many files in /var/log.hdd/journald
  And after midnight is systemd-journald processing all these files from /var/log.hdd/journald and the files are copied to /var/log
  And I don't understand why is it happening. The purpose of logrotate should be reverse. I was expecting, that systemd-journald was working with /var/log/journald and could copy files to /var/log.hdd/journald. But it looks like, that it is merging both folders to /var/log/journald after midnight.
  The question is why and how can I disable it.
  If I delete content from /var/log.hdd/journald, system works for a week. Each day I see, that /var/log.hdd/journald is bigger then day ago. And when is /var/log.hdd/journald bigger then size of my disk at /var/log/journald, the problem is back.
  Nobody has the same problem? My problem is from clean install.
  You can see my log after midnight:
Journal file /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-000000000000b996-0005f4ae0dbec4c9.journal is truncated, ignoring file. [0m
Vacuuming done, freed 0B of archived journals from /var/log/journal.
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-000000000000b996-0005f4ae0dbec4c9.journal (4.0K).
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-00000000000330d4-0005f564f091a604.journal (4.0K).
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@f56508f7111d4e3ca79fed563f198a09-00000000000222fe-0005f47bff7a53af.journal (4.0K).
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-00000000000064fa-0005f49842fb5c37.journal (4.0K).
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/user-1001@cced2c1148944f318fd9acb83811d94d-0000000000021e7e-0005f513d2204368.journal (4.0K).
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/user-1001@e2e99b3d589d4aad8a9740ed778b15f9-0000000000000000-0000000000000000.journal (1.2M).
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/user-1000@3bcf06da2ddd4b70a9b6452bf5c3310e-000000000001dda6-0005f500a159ff44.journal (4.0K).
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@0005f57a3012ba77-535f0c4175b3a77c.journal~ (756.0K).
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-000000000002a097-0005f539a2984d76.journal (4.0K).
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/user-1000@3f221e95a3d04473a4942a383c65c8b4-000000000001feb2-0005f4715b805868.journal (4.0K).
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-000000000001051d-0005f4c2a0f0ac86.journal (4.0K).
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-0000000000010250-0005f4c1d35bb234.journal (4.0K).
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/user-1000@938ade4c383142d8bfdc2b152eb8bfb5-0000000000000000-0000000000000000.journal (1.2M).
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/user-1000@3f221e95a3d04473a4942a383c65c8b4-00000000000232b3-0005f47fb424c433.journal (4.0K).
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-0000000000001e81-0005f485ef5d9270.journal (4.0K).
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-00000000000067cd-0005f498f24672cf.journal (4.0K).
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/user-1000@3bcf06da2ddd4b70a9b6452bf5c3310e-0000000000002784-0005f48814040545.journal (4.0K).
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-0000000000025dc9-0005f5261b2f2f14.journal (4.0K).
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-000000000002635d-0005f527c4c92a62.journal (4.0K).
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-000000000002661b-0005f528a5216131.journal (4.0K).
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-0000000000032b48-0005f5633f9f4466.journal (4.0K).
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@0005f57a234931aa-fb6ef58450ed8353.journal~ (120.0K).
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-000000000002e1ee-0005f54dd27a17ff.journal (4.0K).
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/user-1000@3f221e95a3d04473a4942a383c65c8b4-000000000000a8ee-0005f40b6d1177a6.journal (4.0K).
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-00000000000147bf-0005f4d64b4a1ef4.journal (4.0K).
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-000000000002df2c-0005f54cf772d057.journal (4.0K).
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-000000000002e76f-0005f54f928cbaa2.journal (4.0K).
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-0000000000022458-0005f514e7d7d517.journal (4.0K).
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@f56508f7111d4e3ca79fed563f198a09-0000000000022e66-0005f47ebf530f35.journal (4.0K).
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/user-1001@cced2c1148944f318fd9acb83811d94d-000000000002216f-0005f5146283cc37.journal (4.0K).
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-000000000001dbed-0005f50038f5c6c2.journal (4.0K).
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@f56508f7111d4e3ca79fed563f198a09-0000000000022b8c-0005f47e18b6af59.journal (4.0K).
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@f56508f7111d4e3ca79fed563f198a09-0000000000023144-0005f47f5c58e4ee.journal (4.0K).
Deleted empty archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/user-1000@3bcf06da2ddd4b70a9b6452bf5c3310e-000000000000bd99-0005f4af273bb1a3.journal (4.0K).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/user-1000@2db78b1680be4271961eac68a74e19f8-00000000000004ea-0005f23ed0b5a2a8.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/user-1000@3f221e95a3d04473a4942a383c65c8b4-000000000000093b-0005f3dddff6c3d0.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/user-1000@3f221e95a3d04473a4942a383c65c8b4-0000000000000d12-0005f3deea1d0a8e.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/user-1000@3f221e95a3d04473a4942a383c65c8b4-0000000000000d1c-0005f3deeac7848a.journal (1.0M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/user-1000@3f221e95a3d04473a4942a383c65c8b4-000000000001b718-0005f45c3231644c.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/user-1000@3f221e95a3d04473a4942a383c65c8b4-000000000001c01b-0005f45f032cebe9.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/user-1000@3f221e95a3d04473a4942a383c65c8b4-00000000000205ac-0005f4737307d76c.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@f56508f7111d4e3ca79fed563f198a09-00000000000225d9-0005f47cbef676aa.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@f56508f7111d4e3ca79fed563f198a09-00000000000228b1-0005f47d657ed7e3.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-00000000000018dd-0005f4849c94abcd.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-000000000000215e-0005f4869bdc7a88.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-000000000000243b-0005f4875636bfdb.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-0000000000002714-0005f487fef08d29.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-0000000000006aa3-0005f499b8179bb9.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-0000000000006d6d-0005f49a7e2b9f14.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-000000000000703c-0005f49b3fa571d3.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/user-1000@3bcf06da2ddd4b70a9b6452bf5c3310e-00000000000070fd-0005f49b7446e0bc.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-00000000000072f7-0005f49bf56dde17.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-000000000000b405-0005f4ac7de1e101.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-000000000000b6c9-0005f4ad449ca337.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-000000000000bc5f-0005f4aed845c1eb.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/user-1001@cced2c1148944f318fd9acb83811d94d-000000000000bd77-0005f4af269bafa2.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-000000000000bf17-0005f4af86c5724d.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-000000000000fccc-0005f4c026933ab5.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-00000000000107e4-0005f4c36d31a9c1.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-0000000000010aa7-0005f4c44d27145e.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/user-1001@cced2c1148944f318fd9acb83811d94d-0000000000010b55-0005f4c482dea623.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-0000000000013c94-0005f4d2fb0c6852.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-0000000000013f5d-0005f4d3c9032597.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-0000000000014222-0005f4d4a226351e.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-00000000000144eb-0005f4d57463793a.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-0000000000014a7f-0005f4d71537dd06.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-0000000000014d49-0005f4d7e67e602e.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-0000000000018236-0005f4e7102bc2e5.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-0000000000018502-0005f4e7d91f00fb.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-00000000000187bd-0005f4e8bbade8ce.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-0000000000018a77-0005f4e9a11acdf4.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-0000000000018d36-0005f4ea8a283ee5.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-0000000000018ffe-0005f4eb669989b8.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-00000000000192c0-0005f4ec35c75896.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-000000000001d5b4-0005f4ff1bd36e46.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-000000000001d925-0005f4ff8ca388d9.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/user-1001@cced2c1148944f318fd9acb83811d94d-000000000001d929-0005f4ff8cde4aa0.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/user-1000@3bcf06da2ddd4b70a9b6452bf5c3310e-000000000001d970-0005f4ff94570c32.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/user-1001@cced2c1148944f318fd9acb83811d94d-000000000001dd53-0005f50099960b34.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-0000000000021b97-0005f512ec0ea4ef.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-0000000000021e40-0005f513bfdaf368.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/user-1000@3bcf06da2ddd4b70a9b6452bf5c3310e-0000000000021e8d-0005f513d23882ac.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-000000000002213e-0005f514546e1674.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/user-1000@3bcf06da2ddd4b70a9b6452bf5c3310e-000000000002217e-0005f5146293c06e.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-0000000000025563-0005f523c16ae58b.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-000000000002582c-0005f52496d91efb.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-0000000000025af5-0005f525671239f4.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-0000000000026097-0005f526e614a605.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-000000000002980c-0005f5378bfc7a23.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-0000000000029ad1-0005f53868b60d7b.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-0000000000029dcd-0005f538c631c802.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-000000000002a34d-0005f53a71306dc3.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-000000000002a60d-0005f53b5d5f8a2e.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-000000000002a8d0-0005f53c45c9cce2.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-000000000002ab8d-0005f53d2e4ae9e9.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-000000000002dc5b-0005f54c153c2243.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-000000000002e4a5-0005f54eaf56b206.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-000000000002ea2f-0005f55076135121.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-000000000003203b-0005f55fe20add0d.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-00000000000322f7-0005f560baae2189.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-00000000000325c1-0005f56189b773b1.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-0000000000032883-0005f5626bf9884a.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-0000000000032e11-0005f5641b65716c.journal (576.0K).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-0000000000037cfd-0005f5794de7a3f6.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-0000000000037d6d-0005f57965404b9d.journal (1.2M).
Deleted archived journal /var/log/journal/078479a1b0a4459f80590dd571c3d6de/system@db2ec42ff4cf4233af41703b585ba10a-0000000000037e06-0005f57983b9afda.journal (1.2M).
Vacuuming done, freed 92.8M of archived journals from /var/log/journal/078479a1b0a4459f80590dd571c3d6de.
Vacuuming done, freed 0B of archived journals from /run/log/journal.
Deleted archived journal /run/log/journal/078479a1b0a4459f80590dd571c3d6de/system@3bdefe573aec4437942ac90ad8fb9a78-000000000003e7fb-0005f57a429628c4.journal (1.2M).
Deleted archived journal /run/log/journal/078479a1b0a4459f80590dd571c3d6de/system@3bdefe573aec4437942ac90ad8fb9a78-000000000003ed90-0005f57a43e486d5.journal (1.2M).
Deleted archived journal /run/log/journal/078479a1b0a4459f80590dd571c3d6de/system@3bdefe573aec4437942ac90ad8fb9a78-000000000003f32a-0005f57a44db0b57.journal (1.2M).
Deleted archived journal /run/log/journal/078479a1b0a4459f80590dd571c3d6de/system@3bdefe573aec4437942ac90ad8fb9a78-000000000003f8bf-0005f57a469d9107.journal (1.2M).
Vacuuming done, freed 5.0M of archived journals from /run/log/journal/078479a1b0a4459f80590dd571c3d6de.
But none of the files were in /var/log/journal before midnight. But all of them were in /var/log.hdd/journal before midnight.
Does anybody understand, what's happening?
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
