March 27, 20233 yr Hello! Im trying to get a program called Jetadvice to run on Armbian Bullseye Minimal CLI. I have installed xfce-desktop on the system. Banana Pi BPI-M5 I have installed the required libs linux-libc-dev:armhf and install libc6:armhf. I have added the --add-architecture armhf. But when i start the systemctl processes for the program they stop after a while. I have manage to install the program on the system one time but i have no idea how i manage to get it to work. Did not document it. The EF.JA.Edge.Installer.InstallService fail. It looks okay but the JetAdvice-Edge.service stops after a few seconds. Here is a link to the program and the commands to install it. https://app.jetadvice.com/install/edge/jetadvice-edge-linux-arm.tar If everything works. You should be able to get access to http://localhost:33322 on the computer. Give the program access: sudo chmod +x Installer Run the installation: sudo ./Installer install Starta the following services. JetAdvice-Edge: systemctl start JetAdvice-Edge.service JetAdvice-Updater: systemctl start JetAdvice-Updater.service JetAdvice-Edge-Ui: systemctl start JetAdvice-Edge-UI.service Edited March 27, 20233 yr by Gumzum
