April 3, 20233 yr Hi all, after installing the latest version of Armbian (Jammy 6.1.11 desktop) I found that HDMI monitor audio is not working. With the Ubuntu MATE version of odroid the audio worked. Armbian seems more powerful and its look is much better than MATE, I hope I can solve all the problems because I don't want to go back to MATE anymore, How can I make HDMI audio work? Thanks in advance... PS. I have already updated the firmware to full with the WiFi USB stick problem which has since been resolved
April 6, 20233 yr Hi, try running the script for the 3.5mm jack and also amixer -c 0 set 'TOHDMITX I2S SRC' 'I2S B' I think that has sorted HDMI for me.... I'm trying to get SPDIF working.
April 6, 20233 yr HDMI sudo amixer -c 0 set 'TOHDMITX' 'on' sudo amixer -c 0 set 'TOHDMITX I2S SRC' 'I2S B' sudo amixer -c 0 set 'TDMOUT_B SRC SEL' 'IN 0' sudo amixer -c 0 set 'FRDDR_A SRC 2 EN' 'on' sudo amixer -c 0 set 'FRDDR_A SINK 1 SEL' 'OUT 0' sudo amixer -c 0 set 'FRDDR_A SINK 2 SEL' 'OUT 1' sudo amixer -c 0 set 'FRDDR_A SINK 3 SEL' 'OUT 2' sudo amixer -c 0 set 'ACODEC' '85%' # not needed for the C4 sudo alsactl store ANALOG sudo amixer -c 0 set 'TOACODEC OUT EN' 'on' sudo amixer -c 0 set 'TOACODEC SRC' 'I2S B' sudo amixer -c 0 set 'TDMOUT_B SRC SEL' 'IN 0' sudo amixer -c 0 set 'FRDDR_A SRC 2 EN' 'on' sudo amixer -c 0 set 'FRDDR_A SINK 1 SEL' 'OUT 0' sudo amixer -c 0 set 'FRDDR_A SINK 2 SEL' 'OUT 1' sudo amixer -c 0 set 'FRDDR_A SINK 3 SEL' 'OUT 2' sudo amixer -c 0 set 'ACODEC' '85%' sudo alsactl store
March 19Mar 19 Hi, I am here in 2026 with the Amrbian 26.2.1, I've tried the proposed fix from @c0rnelius but it's not working on my OS version. If anyone has any updated solution that'd be amazing. Thank you
