April 24, 20233 yr The 1-bay NAS kit v1.2 has an RTC with option to add CR2032 button cell to keep HW time when system is shut down. But running `timedatectl` when device is booted in offline mode shows RTC is set to 1970-01-01 00:00:00 which defeats the purpose of having the option of CR2032. And yes, the button cell have juice; I've bought it a week ago and tested it before putting it in the kit.
April 26, 20233 yr Author Allwinner H3 CPU has an in-built RTC which is mounted at /dev/rtc0. This is the reason the RTC doesn't save current time when CPU powers off. The RTC present on the NAS kit (DS1307) needs to be accessed using i2c interface which itself needs to be enabled before doing anything else, and all time sync done with DS1307. Enable i2c (i2c-tools is present in Armbian bullseye by default) by editing /boot/armbianEnv.txt file: sudo nano /etc/armbianEnv.txt in the line overlays=... where "..." means there are already some overlays mentioned, append " i2c" (notice a space before i2c) so that the line should look like overlays=... i2c Save and close. Next, make sure DS1307 module is present in your kernel (it is present in Armbian bullseye by default) sudo modinfo rtc-ds1307 If you see some description and a signature, it is present. Load the module on system start up by adding line to /etc/modules: sudo echo rtc-ds1307 >> /etc/modules Run the following command: sudo i2cdetect -y 0 If you see something like this: 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- 68 -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- then you can see rtc1 in /dev: sudo ls -al /dev/ | grep rtc You need to initialize rtc1 (one time): sudo hwclock --rtc /dev/rtc1 --systohc Create a new file called rtc_ds1307 and add following text (copied from here) by following command: sudo cat <<EOF > rtc && sudo mv rtc /etc/init.d/rtc_ds1307 && sudo chmod +x /etc/init.d/rtc_1307 #! /bin/sh ### BEGIN INIT INFO # Provides: rtc_ds1307 # Required-Start: $remote_fs $syslog # Required-Stop: $remote_fs $syslog # Default-Start: 2 3 4 5 # Default-Stop: 0 1 6 # Short-Description: DS1307 real-time clock usage script # Description: This file should be used to construct scripts to be # placed in /etc/init.d. ### END INIT INFO # PATH should only include /usr/* if it runs after the mountnfs.sh script PATH=/sbin:/usr/sbin:/bin:/usr/bin DESC="ds1307_rtc maintenance service" do_start() { echo "Selecting correct RTC instance" echo ds1307 0x68 > /sys/class/i2c-adapter/i2c-0/new_device sudo ln -f -s /dev/rtc1 /dev/rtc echo "Syncing system time to RTC" #You need to sync from rtc1 instead of default (rtc0) sudo hwclock -s -f /dev/rtc1 } do_stop() { echo "Syncing RTC to system time" sudo hwclock -w } case "\$1" in start) do_start ;; stop) do_stop ;; status) echo "RTC time:" hwclock -r echo "System time:" date ;; restart|force-reload) do_stop ;; *) echo "Usage: rtc_ds1307 {start|stop|status|restart}" >&2 exit 3 ;; esac EOF Update rc.d then reboot: sudo update-rc.d rtc_ds1307 defaults sudo reboot now Check your system time by following command: timedatectl Edited April 27, 20233 yr by Makda Mujji Added code blocks
September 29, 20233 yr Author Few changes to above answer: Edit armbianEnv.txt by sudo nano /boot/armbianEnv.txt And append i2c0 instead of i2c overlays=... i2c0 install i2c-tools sudo apt install i2c-tools If your "sudo i2cdetect -y 0" returns 68, run the following commands first: Load rtc-ds1307 by sudo modprobe rtc-ds1307 sudo echo ds1307 0x68 > /sys/class/i2c-adapter/i2c-0/new_device
April 24Apr 24 Author Solution Starting from Trixie, some paths have changed. Here is the complete walkthrough for the process: Install necessary tools (i2c-tools and hwclock are not present by default in Armbian trixie): sudo apt install i2c-tools util-linux-extra Edit armbianEnv.txt: sudo nano /boot/armbianEnv.txt Append i2c0 to the line that says overlays=...: overlays=... i2c0 ("..." denotes some overlays already written, do not delete them). Reboot (compulsory to load i2c module): sudo reboot now Inquire availability of module rtc-ds1307 in the kernel (present in trixie): sudo modinfo rtc-ds1307 If it returns some description, the module is present. If not, then install its driver from GitHub. Open modules file: sudo nano /etc/modules Add line rtc-ds1307 in it. Save and close. Run the following command: sudo i2cdetect -y 0 It should return 68 in the grid: 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- 68 -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- Then add module to start up: sudo modprobe rtc-ds1307 sudo echo ds1307 0x68 > /sys/class/i2c-dev/i2c-0/device/new_device The DS1307 should now be available at /dev/rtc1, which you can check: sudo ls /dev/ | grep rtc Initialize rtc1 (once) sudo hwclock --rtc /dev/rtc1 --systohc Create a new file rtc_ds1307.sh: sudo nano /usr/local/bin/rtc_ds1307.sh Add following lines in it: #!/bin/bash echo "Creating entry for rtc_1307 service" | systemd-cat -p info sudo echo ds1307 0x68 > /sys/class/i2c-dev/i2c-0/device/new_device echo "Done" | systemd-cat -p info echo "Symlinking /dev/rtc1 to /dev/rtc" | systemd-cat -p info sudo ln -f -s /dev/rtc1 /dev/rtc echo "Done" echo "Syncing RTC time to system time" | systemd-cat -p info sudo hwclock --hctosys --noadjfile --utc -f /dev/rtc1 echo "Done" Save and exit. Make this file executable: sudo chmod +x /usr/local/bin/rtc_ds1307.sh Create a systemd service to run this script at startup: sudo nano /etc/systemd/system/rtc_ds1307.service Add following lines in it: [Unit] Description=Synchronize system clock to RTC Requires=systemd-modules-load.service After=systemd-modules-load.service ConditionPathExists=/sys/class/i2c-dev [Service] Type=oneshot RemainAfterExit=yes ExecStart=/usr/local/bin/rtc_ds1307.sh [Install] WantedBy=multi-user.target Save and exit. Enable the service: sudo chmod 644 /etc/systemd/system/rtc_ds1307.service sudo systemctl enable rtc_ds1307.service Reboot and check system date time by running: timedatectl Edited April 24Apr 24 by Makda Mujji Minor typos and corrections.
