May 23, 20233 yr I've tried many permutations of overlays and user-overlays and I can get /dev/spidev0.0 or /dev/spidev0.1 to be present, but I can't seem to get both simultaneously. I need both to migrate a project from an older Fedora distribution relying on modprobe to the latest version of Armbian. Any suggestions will be greatly appreciated! I started with very recent Armbian 23.02 Bullseye XFCE downloaded from arbian.com/banana-pi-plus .. Armbian_23.02.2_Bananapi_bullseye_current_5.15.93_xfce_desktop.img and I added the following to the /boot/armbianEnv.txt file, as described in the Armbian page associated with the BananaPi M1+ .. fdtfile=sun7i-a20-bananapi-m1-plus.dtb I also added these overlays at the same file .. overlay=spi-spidev spi-add-cs1 param_spidev_spi_bus=0 After reboot, I see one /dev/spidev device: # ls /dev/sp* /dev/spidev0.0 If instead, I also add .. param_spidev_spi_cs=1 Then after reboot, I see a device for the other chip select, only .. # ls /dev/sp* /dev/spidev0.1 but I can't find a means to have access to both simultaneously. As an aside, I also tried the following; Through some searching in the forum, I found a link to a promising overlay .. armbian / sunxi-DT-overlays / examples / spi-double-spidev-cs.dts Contents shown below .. I downloaded this and compiled it using .. dtc -@ -I dts -O dtb -o /boot/overlay-user/spi-double-spidev-cs.dtbo spi-double-spidev-cs.dts Then, since the thread said, "You will still need to use spidev-add-cs1 overlay but remove spi-spidev one because the custom one will be used instead of it," I used the following in the /boot/armbianEnv.txt file .. overlays=spi-add-cs1 user_overlays=spi-double-spidev-cs I confirmed the user overlay did load .. But this produced neither /dev/spidev0.0 or /dev/spidev0.1. Any ideas? I'd rather not have to compile the kernel since I'd have to outfit a whole new development environment for that, so I'm hoping this can be done with dts or dtbo files. Any tips or hints on which direction I should go next will be GREATLY appreciated. Thank you.
June 10, 20233 yr Hi There, Those overlays are a bit old but should hopefully work with one minor change. Try replacing the compatible field with compatible = "armbian,spi-dev" and see if this works. From what I understand there was a change to the kernel since version 5.15 which removed the old spidev driver. Best of luck Ryzer
