Skip to content
View in the app
Armbian Community Forums
[Armbian build PR] - build(deps): bump tj-actions/changed-files from 35 to 36
Featured Replies
Bumps tj-actions/changed-files from 35 to 36.
Release notes
Sourced from tj-actions/changed-files's releases.
v36
Changes in v36.0.9
What's Changed
Full Changelog: https://github.com/tj-actions/changed-files/compare/v36...v36.0.9
Changes in v36.0.8
What's Changed
Full Changelog: https://github.com/tj-actions/changed-files/compare/v36...v36.0.8
Changes in v36.0.7
What's Changed
Full Changelog: https://github.com/tj-actions/changed-files/compare/v36...v36.0.7
Changes in v36.0.6
What's Changed
Full Changelog: https://github.com/tj-actions/changed-files/compare/v36...v36.0.6
Changes in v36.0.5
What's Changed
... (truncated)
Changelog
Sourced from tj-actions/changed-files's changelog.
Changelog
36.0.9 - (2023-05-29)
🐛 Bug Fixes
  • Matching all nested files with a directory name (#1197) (cf4fe87) - (Tonye Jack)
🔄 Update
  • Updated README.md (#1196)
Co-authored-by: jackton1 jackton1@users.noreply.github.com (58c7ce2) - (tj-actions[bot])
  • Update README.md (61316fd) - (Tonye Jack)
  • Update README.md (#1195)
(5d38ef5) - (Tonye Jack)
  • Update README.md (51330c5) - (Tonye Jack)
  • Update README.md (7b92155) - (Tonye Jack)
  • Update README.md (3127174) - (Tonye Jack)
⬆️ Upgrades
  • Upgraded to v36.0.8 (#1192)
Co-authored-by: jackton1 jackton1@users.noreply.github.com (cfdaf8f) - (tj-actions[bot])
36.0.8 - (2023-05-29)
🚀 Features
  • Add support for running on release event (#1191) (043929e) - (Tonye Jack)
⬆️ Upgrades
  • Upgraded to v36.0.7 (#1190)
Co-authored-by: jackton1 jackton1@users.noreply.github.com (96fd197) - (tj-actions[bot])
36.0.7 - (2023-05-29)
🐛 Bug Fixes
  • Bug running changed files with limited history (#1188) (449a845) - (Tonye Jack)
🔄 Update
  • Update README.md (777b2b4) - (Tonye Jack)
  • Update README.md (2fafe0a) - (Tonye Jack)
... (truncated)
Commits
Dependabot compatibility score
Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase.
Dependabot commands and options
You can trigger Dependabot actions by commenting on this PR:
  • @dependabot rebase will rebase this PR
  • @dependabot recreate will recreate this PR, overwriting any edits that have been made to it
  • @dependabot merge will merge this PR after your CI passes on it
  • @dependabot squash and merge will squash and merge this PR after your CI passes on it
  • @dependabot cancel merge will cancel a previously requested merge and block automerging
  • @dependabot reopen will reopen this PR if it is closed
  • @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually
  • @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself)
View the full article
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
