Skip to content
View in the app
Armbian Community Forums
[Armbian build PR] - Fix 32-bit allwinner hang issue by changing stmmac driver to be built as module
Featured Replies
Description
The 32-bit allwinner boards are known to hang with 6.1.30 kernel. On investigation, I was able to narrow the issue down to net-phy-Support-yt8531c.patch and upstream change for lib/mapple tree for some reason these two changes don't seem to be playing along very well. I am trying to get the reason for it, but so far even after enabling low level debugging, hung task detection, earlyprintk and countless such debugging option, I was not able to get more output from the kernel or to get the kernel into kgdb mode. This merge request is raised as a workaround for fixing the hang issue so that other task depending on the same can be unblocked.
Jira reference number AR-1764
How Has This Been Tested?
  • [X] Created an image with the change and booted on Nanopiduo2
Checklist:
  • [X] My code follows the style guidelines of this project
  • [X] I have performed a self-review of my own code
  • [X] I have commented my code, particularly in hard-to-understand areas
  • [X] have made corresponding changes to the documentation
  • [X] My changes generate no new warnings
  • [X] Any dependent changes have been merged and published in downstream modules
View the full article
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
