Skip to content
View in the app
Armbian Community Forums
Cant connect modem Huawei E3372-325 to nano pi
Featured Replies
Hello
I need to connect my modem Huawei E3372-325 to my NanoPI but when i write command ls usb get it
root@PC_42:~# lsusb
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 002: ID 3566:2001
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
When i write in to /etc/usb_modeswitch.conf lines DefaultVendor = 3566
DefaultProduct = 2001
and enter command  sudo usb_modeswitch -v 3566 -p 2001 -c /etc/usb_modeswitch.conf
Look for default devices ...
   product ID matched
 Found devices in default mode (1)
Access device 002 on bus 003
Get the current device configuration ...
Current configuration number is 1
Use interface number 0
 with class 8
USB description data (for identification)
Manufacturer: Mobile
     Product: Mobile
  Serial No.: 123456789ABCD
Warning: no switching method given. See documentation
-> Run lsusb to note any changes. Bye!
I think modem is not connected as well to NanoPI maybe samebody can solve that issue? Maybe i need some libs or drivers?
I have another subtype (and likely older) E3372 device, and remember that after updating it firmware, it acted upon the defaults w.r.t. usb_modeswitch. But it needed newer usb_modeswitch. It was on RPi Debian Buster alike, but usb_modeswitch needed to be newer. Please report your versions.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
