July 3, 20233 yr Hello everyone! Yesterday I downloaded "Armbian 23.5 Jammy". Unfortunately the integrated wifi module does not work. I tried several alternatives but with the same problem. I am not an expert on the subject. Any solution? I'm trying to compile and in one of the steps it tells me that the "Orange Pi 3 LTS - H6" is no longer supported. If anyone knows and can help would be appreciated. https://paste.armbian.com/varepekose Original: Hola a todos! En el dia de ayer descargue "Armbian 23.5 Jammy". Lamentablemente no funciona el modulo wifi integrado. Probe con varias alternativas pero con el mismo problema. No soy un experto en el tema. Alguna solucion? Estoy probando de compilar y en uno de los pasos me toma que la "Orange Pi 3 LTS - H6" ya no esta soportada. Si alguien sabe y puede se agradece la ayuda.
July 5, 20233 yr I was having a similar problem on on Armbian Bookworm. (the ip address section only showed Lo and End0 with no Wlan0 info at all) I downgraded to Armbian Bullseye and now my wi-fi works.
July 7, 20233 yr If updating the firmware or driver doesn't resolve the issue, Consider using an external USB WiFi adapter as an alternative. Many adapters are compatible with Armbian and can provide a reliable wireless connection.
July 7, 20233 yr Probably a dumb question, where is the download link to Bullseye? I see only Bookworm downloads under https://www.armbian.com/orangepi3-lts/, both in the stable and rolling release sections.
July 7, 20233 yr 21 minutes ago, SRM said: Probably a dumb question, where is the download link to Bullseye? I see only Bookworm downloads under https://www.armbian.com/orangepi3-lts/, both in the stable and rolling release sections. We cannot provide images in each and every kernel/userspace constellation for each and every board. Necessary storage and traffic are huge already. You can use the build framework to creat images as needed: https://github.com/armbian/build
July 10, 20233 yr Thanks @Werner. I have no problems building an image on my main computer. I found a working image from this other thread, which is good enough for me right now.
