Skip to content
View in the app
Armbian Community Forums
Building Odroid HC4 image from scratch
Featured Replies
This isn't a question but more of a tutorial.
I wanted to install Debian Bookworm with latest kernel to my odroid. I'm documenting my steps and experience here in case you stumble across it and find it useful.
At the time of writing, the link on the Odroid HC4 site to download Bookworm is broken. No worries, I thought, I'll just build it myself, doesn't seem too hard.
My host system is Windows 10 where I'm building in a WSL 2 Ubuntu. It has GCC 9.3.0 installed.
Follow the usual instructions here. My compilation command is:
./compile.sh KERNEL_CONFIGURE= BUILD_MINIMAL=no BUILD_DESKTOP=no EXTERNAL_NEW=prebuilt BOARD=odroidhc4 BRANCH=edge RELEASE=bookworm SYNC_CLOCK=no EXTRAWIFI=no KERNEL_CONFIGURE=yes BUILD_KSRC=no
I ran into several problems, and fixed them as follows:
  1. Certificates outdated. I hadn't used the WSL2 in a while so the certs for github had expired. I found these commands on stackoverflow:
    sudo apt-get install ca-certificates
    sudo mkdir /usr/local/share/ca-certificates/cacert.org
    sudo wget -P /usr/local/share/ca-certificates/cacert.org http://www.cacert.org/certs/root.crt http://www.cacert.org/certs/class3.crt
    sudo update-ca-certificates
  2. Some error while applying the patch for rtw88 - something to do with Realtek WIFI drivers. Not exactly sure why, and I won't be using one of those anyway, so I just made the patch zero size (deleting it causes it to get redownloaded I think). The compile script will complain about an invalid patch but you can ignore it.
    truncate -s 0 patch/misc/rtw88/6.4/001-rtw88-linux-next.patch
  3. Another Realtek wifi driver issue - this time something in the rtl88x2bu driver that wouldn't compile due to a missing define. Again truncate the patch, or just edit the kernel config to not build Realtek drivers.
    patch/misc/wireless-rtl88x2bu-wireless-ignore-stale-kickoff-removal.patch
Now we can follow along with the normal setup guide. I'm just using HDMI monitor and USB keyboard for now.
It boots up and we can do the initial setup just fine.
Regarding fancontrol: The main HC4 page says to set it up manually. However, it seems to be automatically working for me since the fan is off at idle. The /etc/fancontrol also seems to contain some content already. For me, it was prefilled with:
root@odroidhc4:~# cat /etc/fancontrol
# Default config for the droid HC4 -- adjust to your needs (MINTEMP=40)
INTERVAL=10
DEVPATH=hwmon0=devices/virtual/thermal/thermal_zone0 hwmon2=devices/platform/pwm-fan
DEVNAME=hwmon0=cpu_thermal hwmon2=pwmfan
FCTEMPS=hwmon2/pwm1=hwmon0/temp1_input
FCFANS= hwmon2/pwm1=hwmon2/fan1_input
MINTEMP=hwmon2/pwm1=40
MAXTEMP=hwmon2/pwm1=60
MINSTART=hwmon2/pwm1=150
MINSTOP=hwmon2/pwm1=30
MAXPWM=hwmon2/pwm1=180
I guess this is fine for now.
Let me know if this helps you or if you have a related question!
Thank you for the information. I successfully managed to build "Armbian-unofficial_24.2.0-trunk_Odroidhc4_bookworm_current_6.6.13.img" on my Macbook pro M1. Testing it now.
My build command:
./compile.sh KERNEL_CONFIGURE=no BUILD_MINIMAL=no BUILD_DESKTOP=no EXTERNAL_NEW=prebuilt BOARD=odroidhc4 BRANCH=current RELEASE=bookworm SYNC_CLOCK=no EXTRAWIFI=no KERNEL_CONFIGURE=yes BUILD_KSRC=no INSTALL_HEADERS=yes
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
