Skip to content
View in the app
Armbian Community Forums
RTSP streaming
Featured Replies
Hello is there any way to stream rtsp on H3 devices?
With this i can record video
ffmpeg -t 30 -f v4l2 -channel 0 -video_size 1280x720 -i /dev/video0 -pix_fmt nv12 -r 30 -b:v 64k -c:v cedrus264 test.mp4
My hardware is NanoPI neo air + CAM500B. Using friendlyARM's image at the moment because camera don't work on Armbian. (/dev/video0 is there but mjpg-streamer end with errors for example)
Take a look and try to adjust:
http://www.georgetimmermans.com/blog/streaming-rtsp-to-youtube-live
Making the camera work on Armbian is just a matter of editing script.bin and load the modules.
script.bin section to edit:
[csi0]
vip_used = 1
vip_mode = 0
vip_dev_qty = 1
vip_define_sensor_list = 0
vip_csi_pck = port:PE00<2><default><default><default>
vip_csi_mck = port:PE01<2><default><default><default>
vip_csi_hsync = port:PE02<2><default><default><default>
vip_csi_vsync = port:PE03<2><default><default><default>
vip_csi_d0 = port:PE04<2><default><default><default>
vip_csi_d1 = port:PE05<2><default><default><default>
vip_csi_d2 = port:PE06<2><default><default><default>
vip_csi_d3 = port:PE07<2><default><default><default>
vip_csi_d4 = port:PE08<2><default><default><default>
vip_csi_d5 = port:PE09<2><default><default><default>
vip_csi_d6 = port:PE10<2><default><default><default>
vip_csi_d7 = port:PE11<2><default><default><default>
vip_csi_sck = port:PE12<2><default><default><default>
vip_csi_sda = port:PE13<2><default><default><default>
vip_dev0_mname = "ov5640"
vip_dev0_pos = "rear"
vip_dev0_lane = 2
vip_dev0_twi_id = 2
vip_dev0_twi_addr = 120
vip_dev0_isp_used = 0
vip_dev0_fmt = 0
vip_dev0_stby_mode = 0
vip_dev0_vflip = 0
vip_dev0_hflip = 0
vip_dev0_iovdd = ""
vip_dev0_iovdd_vol = 2800000
vip_dev0_avdd = ""
vip_dev0_avdd_vol = 2800000
vip_dev0_dvdd = ""
vip_dev0_dvdd_vol = 1500000
vip_dev0_afvdd = ""
vip_dev0_afvdd_vol = 2800000
vip_dev0_power_en =
vip_dev0_reset = port:PE14<1><default><default><default>
vip_dev0_pwdn = port:PE15<1><default><default><default>
vip_dev0_flash_en =
vip_dev0_flash_mode =
vip_dev0_af_pwdn =
vip_dev0_act_used = 0
vip_dev0_act_name = "ad5820_act"
vip_dev0_act_slave = 24
vip_dev1_mname = ""
vip_dev1_pos = "rear"
vip_dev1_lane = 1
vip_dev1_twi_id = 0
vip_dev1_twi_addr =
vip_dev1_isp_used = 0
vip_dev1_fmt = 1
vip_dev1_stby_mode = 0
vip_dev1_vflip = 0
vip_dev1_hflip = 0
vip_dev1_iovdd = ""
vip_dev1_iovdd_vol = 2800000
vip_dev1_avdd = ""
vip_dev1_avdd_vol = 2800000
vip_dev1_dvdd = ""
vip_dev1_dvdd_vol = 1500000
vip_dev1_afvdd = ""
vip_dev1_afvdd_vol = 2800000
vip_dev1_power_en =
vip_dev1_reset =
vip_dev1_pwdn =
vip_dev1_flash_en =
vip_dev1_flash_mode =
vip_dev1_af_pwdn =
Add the modules to load in /etc/modules
ov5640
vfe_v4l2
We need just the specific Armbian image for the Air and how to setup wifi instructions without resorting to TTL serial debug.
  • Author
Already tried editing the file and modules list, after that /dev/video0 appeared but not working with software. Will try it one more time.
Regarding wifi - the stable image here https://www.armbian.com/nanopi-neo-air/  don't have nmtui installed, or at least a week ago it hadn't. Development version does.
  • Author
Regarding streaming - thanks for the link but the question is more about how to "produce" the stream on device, like making rtsp camera from nanopi.
So it's usable with motioneye or zoneminder.
Sorry if i was unclear.
mjpg-streamer will not work with Armbian (for now), try to compile fswebcam from source: https://github.com/avafinger/fswebcamif you can setup a working image.
It would be nice just to edit the file, write ssid and psk and that was it.
will research for the RSTP and try to make it work.
  • Author
I can see that configuration file for my wlan connection is located in /etc/NetworkManager/system-connection
Maybe it will also work if we make that file before the first boot.
  • Author
 Done, but no go.
root@nanopiair:~# fswebcam --verbose
--- Opening /dev/video0...
Trying source module v4l2...
/dev/video0 opened.
src_v4l2_get_capability,87: /dev/video0 information:
src_v4l2_get_capability,88: cap.driver: "sunxi-vfe"
src_v4l2_get_capability,89: cap.card: "sunxi-vfe"
src_v4l2_get_capability,90: cap.bus_info: "sunxi_vfe sunxi_vfe.0"
src_v4l2_get_capability,91: cap.capabilities=0x05000001
src_v4l2_get_capability,92: - VIDEO_CAPTURE
src_v4l2_get_capability,101: - READWRITE
src_v4l2_get_capability,103: - STREAMING
No input was specified, using the first.
src_v4l2_set_input,181: /dev/video0: Input 0 information:
src_v4l2_set_input,182: name = ""
src_v4l2_set_input,183: type = 00000002
src_v4l2_set_input,185: - CAMERA
src_v4l2_set_input,186: audioset = 00000000
src_v4l2_set_input,187: tuner = 00000000
src_v4l2_set_input,188: status = 00000000
src_v4l2_set_pix_format,551: Device offers the following V4L2 pixel formats:
src_v4l2_set_pix_format,564: 0: [0x50323234] '422P' (planar YUV 422)
src_v4l2_set_pix_format,564: 1: [0x32315559] 'YU12' (planar YUV 420)
src_v4l2_set_pix_format,564: 2: [0x32315659] 'YV12' (planar YVU 420)
src_v4l2_set_pix_format,564: 3: [0x3631564E] 'NV16' (planar YUV 422 UV combined)
src_v4l2_set_pix_format,564: 4: [0x3231564E] 'NV12' (planar YUV 420 UV combined)
src_v4l2_set_pix_format,564: 5: [0x3136564E] 'NV61' (planar YUV 422 VU combined)
src_v4l2_set_pix_format,564: 6: [0x3132564E] 'NV21' (planar YUV 420 VU combined)
src_v4l2_set_pix_format,564: 7: [0x32314D48] 'HM12' (MB YUV420)
src_v4l2_set_pix_format,564: 8: [0x56595559] 'YUYV' (YUV422 YUYV)
src_v4l2_set_pix_format,564: 9: [0x55595659] 'YVYU' (YUV422 YVYU)
src_v4l2_set_pix_format,564: 10: [0x59565955] 'UYVY' (YUV422 UYVY)
src_v4l2_set_pix_format,564: 11: [0x59555956] 'VYUY' (YUV422 VYUY)
src_v4l2_set_pix_format,564: 12: [0x31384142] 'BA81' (RAW Bayer BGGR 8bit)
src_v4l2_set_pix_format,564: 13: [0x47524247] 'GBRG' (RAW Bayer GBRG 8bit)
src_v4l2_set_pix_format,564: 14: [0x47425247] 'GRBG' (RAW Bayer GRBG 8bit)
src_v4l2_set_pix_format,564: 15: [0x47425247] 'GRBG' (RAW Bayer RGGB 8bit)
src_v4l2_set_pix_format,564: 16: [0x30314742] 'BG10' (RAW Bayer BGGR 10bit)
src_v4l2_set_pix_format,564: 17: [0x30314247] 'GB10' (RAW Bayer GBRG 10bit)
src_v4l2_set_pix_format,564: 18: [0x30314142] 'BA10' (RAW Bayer GRBG 10bit)
src_v4l2_set_pix_format,564: 19: [0x30314142] 'BA10' (RAW Bayer RGGB 10bit)
src_v4l2_set_pix_format,564: 20: [0x32314742] 'BG12' (RAW Bayer BGGR 12bit)
src_v4l2_set_pix_format,564: 21: [0x32314247] 'GB12' (RAW Bayer GBRG 12bit)
src_v4l2_set_pix_format,564: 22: [0x32314142] 'BA12' (RAW Bayer GRBG 12bit)
src_v4l2_set_pix_format,564: 23: [0x32314142] 'BA12' (RAW Bayer RGGB 12bit)
Using palette RGB24
Adjusting resolution from 384x288 to 320x240.
Error setting pixel format.
VIDIOC_S_FMT: Operation not permitted
root@nanopiair:~# ls /dev/video0
/dev/video0
root@nanopiair:~# fswebcam -r 1280x720 --save test.jpg
/dev/video0 opened.
root@nanopiair:~#
/dev/video0 was there after changing fex
Using Armbian_5.24.161214_Nanopiair_Ubuntu_xenial_3.4.113
  • Author
That works, so we need YUV420P.
What do you think about this?
https://github.com/mpromonet/v4l2tools
  • v4l2compress_omx :
read YUV420 from a V4L2 capture device, compress in H264 format using OMX and write to a V4L2 output device
  • Author
These don't work for me at the moment because "Tools for Raspberry" don't compile on H3 platform.
  • Author
Sorry, i don't have experience with OMX.
I would use Cedrus264 instead to save CPU, HW encode even with those limitation. You can build your own FFmpeg and add what you need. FFmpeg is complex to learn but here are some guide that may help:
https://trac.ffmpeg.org/wiki/StreamingGuide
You can find additional working here:  https://github.com/uboborov/ffmpeg_h264_H3
Thank you. I can see it is complex, so maybe you could provide me a command to convert from YUV420 to H264 from one device to another using v4l2loopback.
That would save me much time i think.
  • Author
I managed to have it all working like this: ffmpeg > udp streaming > vlc > rtsp streaming > motioneye rtsp camera
The commands are:
ffmpeg -f v4l2 -i /dev/video0 -f mpegts -b:v 5000000 udp://192.168.43.130:1300
cvlc -vvv udp://@192.168.43.130:1300fifo_size=10000 --sout '#rtp{sdp=rtsp://@192.168.43.130:8731/go}'
After that i can ad  a camera to motioneye and have rtsp video source with huge latency (~5 sec)
CPU usage on every core is 40-50% (Nanopi neo air) WITHOUT motioneye (on the other pc). So, only for encoding and streaming.
Would be nice to find a solution to encode with Cedrus freeing the CPU cores.
With this
ffmpeg -f v4l2 -i /dev/video0 -f mpegts -b:v 64k -pix_fmt nv12 -c:v cedrus264 udp://192.168.43.130:1300
FFmpeg starts working but vlc shows
[b380d0e0] packetizer_h264 decoder warning: waiting for SPS/PPS
[b3a00508] core input debug: Buffering 10%
[b3a00508] core input debug: Buffering 13%
[b3a00508] core input debug: Buffering 16%
[b3a00508] core input debug: Buffering 20%
[b3a00508] core input debug: Buffering 23%
[b3a00508] core input debug: Buffering 26%
[b3a00508] core input debug: Buffering 30%
[b3a00508] core input debug: Buffering 33%
[b3a00508] core input debug: Buffering 36%
[b3a00508] core input debug: Buffering 40%
[b3a00508] core input debug: Buffering 43%
[b3a00508] core input debug: Buffering 46%
[b3a00508] core input debug: Buffering 50%
[b3a00508] core input debug: Buffering 53%
[b3a00508] core input debug: Buffering 56%
[b3a00508] core input debug: Buffering 60%
[b3a00508] core input debug: Buffering 63%
[b3a00508] core input debug: Buffering 66%
[b3a00508] core input debug: Buffering 70%
Why i'm doing it? Trying to find a way to achieve more than 1-3 fps with camera board on Nanopi for biggest resolitions with built-in motion detection and video saving.
One another question - can i somehow control exposure time of CAM500B?
Not sure if it is what you want, try something like this:
struct v4l2_control control;
int rc;
memset(&control, 0, sizeof(control));
control.value = exposure;
rc = ioctl(fd, VIDIOC_S_CTRL, &control);
values [-4,4]
  • Author
This should be a better command
ffmpeg -f v4l2 -video_size 1280x720 -i /dev/video0 -pix_fmt nv12 -r 25 -maxrate 1000k -b:v 500k -c:v cedrus264 -f mpegts - | cvlc - --sout "#:rtp{sdp=rtsp://192.168.43.176:8554/go}"
1080p can also be encoded but with 1-2 fps
And there are many lags
I tried the examples for example:
but I get an error "Unknown encoder 'cedrus264'"
How do I download it. I an using Armbian & OrangePi PC and a sunxi ribbon camera.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
