November 26, 20232 yr Apt lists Armbian 23.8.3 as upgradable but refuses to upgrade. According to apt-cache the base files for 23.8.3 have not been updated for Orangepi3-lts. Is this the case or do I have a local problem with my install? --------------- # apt-cache policy base-files base-files: Installed: 23.8.1-bullseye Candidate: 23.8.1-bullseye Version table: *** 23.8.1-bullseye 500 500 http://apt.armbian.com bullseye/main arm64 Packages 100 /var/lib/dpkg/status 11.1+deb11u8 500 500 http://deb.debian.org/debian bullseye/main arm64 Packages
November 26, 20232 yr Hey @Timo12357 this was identified before. Check https://github.com/armbian/build/pull/5766 Please check against beta/testing repo? Thanks
