December 9, 20232 yr Trying to get some S/W working but it requires clang 16 (or later). Current distro only has Clang 14. Do I need to clone/build llvm?
December 9, 20232 yr Solution moved to userspace 3 hours ago, mjz said: Do I need to clone/build llvm? Either that or find a different way to get it running on your system. https://www.google.com/searchq=clang+16+ubuntu+22.04
December 9, 20232 yr Author Thank you, Werner. I was doing "clang 16 armbian" and trying to see if there were prebuilt packages...
