Skip to content
View in the app
Armbian Community Forums
[Armbian build PR] - RFC: mixtile-blade3 / rockchip-rk3588 edge 6.7: add DT from Joshua Riek + some fixes
Featured Replies
  • mixtile-blade3 / rockchip-rk3588 edge 6.7: add DT (original from Joshua Riek)
  • mixtile-blade3 / rockchip-rk3588 edge 6.7: cleanups for Mixtile Blade3
    • arm64: dts: rockchip: cleanups for Mixtile Blade3
    • drop hym8563 pinctrl (don't think the blade3 has an RTC)
    • i2c5 is exposed on the 30-pin, add comment
    • fix tab in pcie30phy
  • mixtile-blade3 / rockchip-rk3588 edge 6.7: pci3x4 for Mixtile Blade3 (rpardini's bad take)
    • arm64: dts: rockchip: pci3x4 for Mixtile Blade3
    • pinctrl for 1 RK_PB2 pull_up
    • regulator vcc3v3_pcie30 always-on and boot-on
      • there is probably a much better fix than this, but I couldn't find it
  • mixtile-blade3 / rockchip-rk3588 edge 6.7: slow down eMMC from hs400 to hs200
  • mixtile-blade3 / rockchip-rk3588-edge 6.7: enable tsadc for thermal sensors
    • thanks AmazingFate
  • mixtile-blade3: enable edge branch with new dt; all branches use vendor u-boot
here's some work I've been sitting on for a while for the Mixtile Blade3 - schematics - vendor kernel DT
I took @Joshua-Riek 's DT and worked it a bit. All credit to him.
Most stuff works, but it's not really stable, and pcie3x4 works "sometimes". Similar stuff works for (vendor) u-boot, where it always works.
I'm using their u.2 to m.2 breakout board.
Any ideas?
View the full article
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
