Skip to content
View in the app
Armbian Community Forums
  1. Tap the 3-dot menu (โ‹ฎ) in the top-right corner of the browser.
[Armbian build PR] - Disable md5 packages check on unsupported distributions
Featured Replies
Description
Unstable / testing packages sometimes contain hacks that are patching files. Fixing this in Debian Sid / Trixie
Not sure why this happens, but we certainly don't need this check in rolling releases.
  [๐Ÿณ|๐ŸŒฑ] Checking MD5 sum of installed packages [ debsums ]
  [๐Ÿณ|๐Ÿ”จ]   debsums: changed file /usr/sbin/start-stop-daemon (from dpkg package)
  [๐Ÿณ|๐Ÿ’ฅ] Error 2 occurred in main shell [ at /armbian/lib/functions/logging/runners.sh:211
How Has This Been Tested?
  • [x] Manual run
Checklist:
  • [x] I have commented my code, particularly in hard-to-understand areas
  • [ ] I have made corresponding changes to the documentation
  • [x] Any dependent changes have been merged and published in downstream modules
View the full article
I also experienced this issue with a kde-plasma ubuntu 24.04 (noble image build of 24.8.0 edge) on an Orange Pi 5 plus (16gb). Disabling the above code per the commit avoided the issue and the result was a successful image generation.
Hi @ioncube
ย
Apologies for the late reply.
ย
Although not recommended practice, in my 24.8.0 build tree, I commented out the debsums invocation - i'm sure its fine ๐Ÿ˜€
The relevant part of lib/functions/rootfs/rootfs-create.sh in my build tree reads:
ย
        if [[ "${DISTRIBUTION_STATUS}" == "supported" || "${FORCE_CHECK_MD5_PACKAGES:-"no"}" == "yes" ]]; then
                display_alert "Checking MD5 sum of installed packages" "debsums" "info"
                declare -g if_error_detail_message="Check MD5 sum of installed packages failed"
                #chroot_sdcard debsums --silent
        fi
and that should prevent the problem. Perhaps settings FORCE_CHECK_MD5_PACKAGES=no during ./compile.sh invocation might work also?
ย
Its a difficult one to work around due to random mirrors, cache contents etc... very sporadic.
ย
Andrew
Account
Navigation
Search
Search
Chrome (Android)
  2. Tap Permissions โ†’ Notifications.
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
