Skip to content
View in the app
Armbian Community Forums
[Armbian build PR] - rk35xx-vendor: add rk3528 and lima driver support
Featured Replies
Description
Enable rk3528 soc support to make rk3528 boards bootable. Enable lima gpu driver for mali 400/450 gpu on rk3528 and disable arm mali400/450 driver. Devicetree related change is already in https://github.com/amazingfate/linux-rockchip/commit/419410ff56c8e80b37e100c265d57f23cc0db835
How Has This Been Tested?
Please describe the tests that you ran to verify your changes. Please also note any relevant details for your test configuration.
  • [x] ./compile.sh kernel BOARD=hinlink-ht2 BRANCH=vendor DEB_COMPRESS=xz KERNEL_CONFIGURE=no
  • [x] Lima gpu driver works on hinlink-ht2
Checklist:
  • [x] My code follows the style guidelines of this project
  • [x] I have performed a self-review of my own code
  • [ ] I have commented my code, particularly in hard-to-understand areas
  • [ ] I have made corresponding changes to the documentation
  • [x] My changes generate no new warnings
  • [ ] Any dependent changes have been merged and published in downstream modules
View the full article
Hello, thk work fine on my X88 pro13
Here is : Armbian_community_26.2.0-trunk.332_Hinlink-ht2_noble_vendor_6.1.115_gnome_desktop.img
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
