March 11, 20242 yr Hi everyone, i have uptabte armbian from 23.05 to 24.1 (stable relase update) in my nano pi neo air, but arter update i cant connect to device via com port from micro usb. (no avalible devices, when i connect nanopi to my PC) How i can fix it? Armbian-config? P.S. I also soldering external usb-uart and to the nano and i see that update was sucsessful, device steel working.
July 4, 20251 yr Hello @Aknot, better late than never? This is likely because USB OTG support is on out of the box now. You used to have to add an overlay to get it to work. You will need to modify the the overylays to change this.
