Skip to content
View in the app
Armbian Community Forums
[OrangePi Plus 2] Question with external DD in usb more than 2to
Featured Replies
I want to branch a disque that have 3to or 4to to do my personnal backup of data.
Can I do this ? Can I branch it in the usb and do this ?
I format in ext4 ? or ntfs ? (with gpt mode).
Thanks
  • Author
According to https://linux-sunxi.org/Xunlong_Orange_Pi_Plus#SATA this should work,
if you provide sufficient power of good quality.
There seems to be no 2TB limit mentioned in the gl830 sata bridge datasheet
here: http://pdf1.alldatasheet.com/datasheet-pdf/view/207044/GENESYS/GL830.html
best, gnasch
Thanks but i mean not in sata but in usb device.
I test with HGST 3To it works with GPT mode and ntfs but when restart with HHD conect allthe system failed. nothing appear in screen.
Alqso if i debranch HDD not start.
I must reinstall all the system ....
Hi
Please verify quality of your power supply and your cabling.
HDD motor takes a lot of current when starting.
  • Author
Hello
I use a hdd and a box separatly.....
Hdd infernal and case with USB
That problem is nuit when i plug in the system when it works but when after want to reboot the system failed to restart and kill the kernel....
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
