Skip to content
View in the app
Armbian Community Forums
3TB WD Green only recognized as 800GB drive
Featured Replies
I have a 3TB drive attached via SATA, with independent PSU. Despite my best efforts I cannot get it to be recognized as anything more than 801GB/746GiB. This drive works in another machine fine. I tried a low-level wipe (dd if=/dev/zero of=/dev/sda bs=1M), as well as creating new GPT partition tables.
hdparm -I does correctly report info, but `cat /sys/class/block/sda/queue/physical_block_size` reports block size at 512. Any thoughts?
Device Details:
Orange Pi+ 2
Armbian Debian 3.4 image
Linux XX 3.4.113-sun8i #10 SMP PREEMPT armv7l GNU/Linux
WD 3TB Green (WD30EZRX)
OS installed on eMMC on system
Excerpt from kernel log when attaching drive:
[    4.534594] sd 0:0:0:0: [sda] 1565565868 512-byte logical blocks: (801 GB/746 GiB)
[    4.550334] sd 0:0:0:0: [sda] Write Protect is off
[    4.561887] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
[    4.562827] sd 0:0:0:0: [sda] No Caching mode page found
[    4.574843] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    4.590700] sd 0:0:0:0: [sda] No Caching mode page found
[    4.623980] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    4.698642]  sda: sda1
[    4.702202] sd 0:0:0:0: [sda] No Caching mode page found
[    4.702214] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    4.702226] sd 0:0:0:0: [sda] Attached SCSI disk
hdparm -I :
ATA device, with non-removable media
        Model Number:       WDC WD30EZRX-00MMMB0
        Serial Number:      WD-WCAWZ1242100
        Firmware Revision:  80.00A80
        Transport:          Serial, SATA 1.0a, SATA II Extensions, SATA Rev 2.5, SATA Rev 2.6, SATA Rev 3.0
Standards:
        Supported: 8 7 6 5
        Likely used: 8
Configuration:
        Logical         max     current
        cylinders       16383   16383
        heads           16      16
        sectors/track   63      63
        CHS current addressable sectors:   16514064
        LBA    user addressable sectors:  268435455
        LBA48  user addressable sectors: 5860533168
        Logical  Sector size:                   512 bytes
        Physical Sector size:                  4096 bytes
        Logical Sector-0 offset:                  0 bytes
        device size with M = 1024*1024:     2861588 MBytes
        device size with M = 1000*1000:     3000592 MBytes (3000 GB)
        cache/buffer size  = unknown
Capabilities:
        LBA, IORDY(can be disabled)
        Queue depth: 32
        Standby timer values: spec'd by Standard, with device specific minimum
        R/W multiple sector transfer: Max = 16  Current = 0
        DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 *udma4 udma5 udma6
             Cycle time: min=120ns recommended=120ns
        PIO: pio0 pio1 pio2 pio3 pio4
             Cycle time: no flow control=120ns  IORDY flow control=120ns
  • Author
OK, well it should be slower than crap but should still recognize the drive correctly, right?
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
