Skip to content
View in the app
Armbian Community Forums
[Armbian build PR] - add customized GHCR_MIRROR_ADDRESS support
Featured Replies
Description
dockerproxy.com is not avaiable from China mainland, but there are many alternative mirrors, for example we can deploy one to cloudflare: https://github.com/ciiiii/cloudflare-docker-proxy I have deployed mine: ghcr.haguro.top
Documentation summary for feature / change
Please delete this section if entry to main documentation is not needed.
If documentation entry is predicted, please provide key elements for further implementation into main documentation and set label to "Needs Documentation". You are welcome to open a PR to documentation or you can leave following information for technical writer:
  • [x] short description: customized GHCR_MIRROR_ADDRESS
  • [x] summary: Default mirror address for ghcr.io set by GHCR_MIRROR=dockerproxy is ghcr.dockerproxy.com. When this address is not availabe, we can set an alternative address with GHCR_MIRROR_ADDRESS.
  • [x] example of usage: ./compile.sh GHCR_MIRROR=dockerproxy GHCR_MIRROR_ADDRESS=ghcr.libcuda.so
How Has This Been Tested?
  • [x] ./compile.sh BOARD=rock-5b BRANCH=edge BUILD_MINIMAL=no DEB_COMPRESS=xz DOWNLOAD_MIRROR=china KERNEL_CONFIGURE=no RELEASE=bookworm BUILD_DESKTOP=yes DESKTOP_APPGROUPS_SELECTED= DESKTOP_ENVIRONMENT=gnome DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base GHCR_MIRROR_ADDRESS=ghcr.haguro.top GHCR_MIRROR=dockerproxy
Checklist:
Please delete options that are not relevant.
View the full article
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
