Skip to content
View in the app
Armbian Community Forums
Armbian Bleeding edge releases sans network-manager sur orangepi3b v2.1 SoC Rockchip RK3566
Featured Replies
I tried to set armbian without networkmanager or netplan, with just ifupdown, isc-dhcp-client and wpasupplicant, but the wlan0 interface doesn't work as expected. IP Link Set WLAN0 Up doesn't want to set the interface to UP. With Network-Manager, the interface works correctly from the start. Do you have a solution to do without Network Manager and Netplan? I would just like to configure /etc/networkinterfaces like on my laptop. Thank you in advance for your answers
Solved by Well
Hello again @Well
I'm not seeing a lot of response to your question so I will make a suggestion.
I'm guessing that you are using one of the Ubuntu based Armbian builds?
Perhaps Jammy?
I have not tried this, but this but these Ubuntu instructions may work.  Please let us know if this works.
https://tech.sadaalomma.com/ubuntu/how-to-remove-netplan-ubuntu-20-04/
  • Author
I just reinstalled the native Debian Bookworm image  https://github.com/armbian/community/releases/download/24.8.0-trunk.399/Armbian_community_24.8.0-trunk.399_Orangepi3b_bookworm_edge_6.9.9_minimal.img.xz taken here: https://www.armbian.com/orangepi3b/ -->Bleeding edge releases with Armbian Linux v6.9 because this -->Server and IOT releases with Armbian Linux v6.1 does not boot on the orangepi3b v2.1
/etc/network/interfaces (as on my laptop)
auto lo
iface lo inet loopback
auto end0
allow-hotplug end0
iface end0 inet static
       address 192.168.100.103
       gateway 192.168.100.1
auto wlan0
allow-hotplug wlan0
iface wlan0 inet static
       address 192.168.100.102
       wpa-conf   /etc/wpa_supplicant/wpa_supplicant.conf
The /etc/wpa_supplicant/wpa_supplicant.conf
ctrl_interface=/var/run/wpa_supplicant
eapol_version=1
ap_scan=1
fast_reauth=1
update_config=1
network={
                  ssid="MyNetwork"
                  psk="MyPasswd"
Network-manager is not intalled
I installed ifupdown
i deleted netplan.io
/sbin/reboot
The network is working on end0 but the wlan0 interface is not working.
end0 is UP
wlan0 is DOWN
ifdown end0
ip -c a --> end0 DOWN, wlan0 DOWN but there is ip 192.168.100.102 displayed !
ip link set wlan0 up (or ip link set dev wlan0 up) --> does not work
ifup wlan0 --> BROADCAST,MULTICAST,UP, LOWER_UP --> STATE UP
inet 192.168.100.102/24 brd 192.168.100.255 scope global wlan0
Ping 8.8.8.8 --> no ping
ping : unknow host
ifdown wlan0 --> ifdown: interface wlan0 not configured
BUT ip -c a --> wlan0 --> state UP and IP is displayed !
To summarize, the network works normally with the end0 interface but not with WLAN0 without netplan.io For wlan0 with ip -c a --> the ip is always displayed whether the state is on UP or DOWN and the ping doesn't work! I tried to see if it was my card that didn't work by installing network-manager and everything works normally of course without /etc/network/interfaces!
systemctl restart networking.service --> does not restart!
systemctl status networking.service --> "failed to initialize control nterface /var/run/wpa_supplicant You may have another wpa_supplicant process already running or the file was left by an unclean termination of wpa_supplicant in which case you will need to manually remove this file before starting wpa_supplicant again."
apt remove --purge wpasupplicant
apt install wpasupplicant
/sbin/reboot
wlan0 is DOWN but ip 192.168.100.102 is displayed
networking.service - Raise network interfaces
Loaded: enable
Active: failed
Process: ExecStart=/sbin/ifup -a --read-environment (code=exited, status=1/FAILURE)
  • Author
In order to avoid duplicates and software overlays, I tried to go back to a native configuration with systemd-networkd and wpasupplicant so without ifupown and without /etc/network/interfaces. So I reinstalled an original bookworm 12 image whose link is mentioned in a previous message, rm /etc/netplan/*, deleted netplan.io and then configured two interfaces in /etc/systemd/network/10-static-end0.network and /etc/systemd/network/20-static-wlan0.network. In each file the following conf with the correct ip :
Match] Name=end0|wlan0
[Network] Address=192.168.100.103/24|192.168.100.102/24
Gateway=192.168.100.1
DNS=8.8.8.8
Recreated the conf of /etc/wpa_supplicant/wpa_supplicant.conf Then reboot the system. end0 works fine but again impossible to reactivate wlan0. Perhaps, I have forgotten a statement? A bit like wpa-conf... in /etc/network/interfaces Thank you in advance for your answers.
  • Author
I bought a tp-link usb key model TL-WN725N. It was a little too complicated to set up
https://static.tp-link.com/2018/201812/20181207/Installation Guide for Linux.pdf
So I dove back into the system. It works now. Here is the procedure:
Orangepi3b v2.1 Bleeding edge images with Armbian Linux v6.9 --> Debian 12 (Bookworm) Minimal / IOT at https://www.armbian.com/orangepi3b/
Basic installation (without network-manager and without ifupdown). Configuring interfaces with only systemd-network + wpasupplicant
Deletion of Netplan :
apt remove --purge netplan.io
rm -Rf /etc/netplan/*
rmdir /etc/netplan/
rm /run/systemd/network/10-netplan-all-eth0-interfaces.network
rm /etc/systemd/network/00-armbian-readme.network
vim /etc/systemd/network/10-end0-static.network
[Match]
Name=end0
[Network]
DNS=8.8.8.8
vim /etc/systemd/network/15-end0-dhcp.network
[Match]
Name=end0
[Network]
DHCP=yes
Do the same with the wlan0 interface with another IP for the static part (of course)
vim /etc/systemd/network/20-wlan0-static.network
vim /etc/systemd/network/25-wlan0-dhcp.network
vim /etc/wpa_supplicant/wpa_supplicant.conf
ctrl_interface=/var/run/wpa_supplicant   GROUP=netdev
eapol_version=1
ap_scan=1
fast_reauth=1
update_config=1
network={
               ssid="ssid"
               psk="password"
               key_mgmt=WPA-PSK
The following conf is also important :
vim /etc/systemd/system/wpa_supplicant@wlan0.service
[Unit]
Description=WPA supplicant for %i
Wants=network.target
Before=network.target
After=sys-subsystem-net-devices-%i.device
[Service]
Type=simple
ExecStart=/sbin/wpa_supplicant -c /etc/wpa_supplicant/wpa_supplicant.conf -i %i
ExecReload=/bin/kill -HUP $MAINPID
Restart=always
RestartSec=5
[Install]
WantedBy=multi-user.target
systemctl daemon-reload
systemctl enable systemd-networkd
systemctl start systemd-networkd
systemctl enable wpa_supplicant@wlan0.service
systemctl start wpa_supplicant@wlan0.service
Check that everything works
systemctl status systemd-netword
systemctl status wpa_supplicant@wlan0.service
Normally it works!
ip -c a
ip link set end0|wlan0 up|down
I tried to modify the file /etc/systemd/system/dbus-fi.w1.wpa_supplicant1.service to avoid recreating another service (the file /etc/systemd/system/wpa_supplicant@wlan0.service) but I didn't succeed.
It must be possible to make it even simpler. If you have any suggestions, I'm interested ;)
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
