Skip to content
View in the app
Armbian Community Forums
Banana Pi with DVB Support
Featured Replies
I tried to rebuild the Banana Pi image with kernel 3.19.7 adding the configuration from here to the next config before rebuilding. I get a lot of prompts and I said m for modular or Y for yes to each of them.
The tuner still isn't showing up in Tvheadend. I can donate some BTC so you have a test unit to help get this working.
  • Author
After installing the drivers I do get this but I can't use it in any dvb app I try. The overall procedure I used was exactly the same as what is working on the Raspberry Pi with Minibian.
[  243.265567] usb 1-1: new high-speed USB device number 2 using ehci-platform
[  243.416735] usb 1-1: New USB device found, idVendor=2013, idProduct=025f
[  243.416754] usb 1-1: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[  243.416765] usb 1-1: Product: PCTV 292e
[  243.416774] usb 1-1: Manufacturer: PCTV
[  243.416783] usb 1-1: SerialNumber: 0011443350
The USB device shows up but I think at least those lines don't show any driver taking it. You might still be missing the right one.
Do you get any /dev/video* files?
  • Author
XTL, it is the exact same driver I used on the Pi 2 which is also an ARMv7 device. I am fairly certain this is a kernel issue as others on the lemaker forum have had to recompile kernels to support DVB devices for Bananian.
I tried lot of things to make my usb tuner working on this kernel, but after unsuccess I loaded 3.4.1XX kernel. After that Mythtv on my BananaPi recorded first tv show/movie and still working from the 20 of March this year.
  • Author
Any specific kernel parameters you used to make it work?
Ideally I would like modular SATA PMP support and DVB, not have different images for both, hopefully it's possible. Igor, any ideas, do you want the test unit?
I don't use any specific kernel parametres. I only checked "dmesg|grep dvb" after I plugged dvbt stick in and added firmware from my desktop ubuntu based system into /lib/firmware folder. Here is normal output of command above:
dmesg|grep dvb
[   17.094246] dvb-usb: found a 'Kworld UB499-2T T09(IT9137)' in warm state.
[   17.165743] dvb-usb: will use the device's hardware PID filter (table count: 31).
[   17.522765] dvb-usb: will use the device's hardware PID filter (table count: 31).
[   18.313846] dvb-usb: schedule remote query interval to 250 msecs.
[   18.328144] dvb-usb: Kworld UB499-2T T09(IT9137) successfully initialized and connected.
lsusb
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 002: ID 1b80:e409 Afatech IT9137FN Dual DVB-T [KWorld UB499-2T]
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
