Skip to content
View in the app
Armbian Community Forums
Consistent SSH host key setup when cloud-init / armbian-firstrun are both executed
Featured Replies
Hi,
Context
systemd's cloud-init.target and armbian-firstrun.service will be started concurrently (both are wanted by multi-user.target). Both will try to create SSH host keys by default:
 - armbian-firstrun will always delete SSH host keys and then generate new ones
 - cloud-init.target (by default) will always delete SSH host keys and then generate new ones.
Problem
When one must run armbian-firstrun and cloud-init, there is no deterministic ordering between the 2 files execution and therefore no one can guarantee which will be last to setup host keys. In my current scenario, host keys are explicitly setup in cloud-init and I would expect armbian-firstrun to not delete keys + no ssh host key generation.
Proposed Solution
armbian-firstrun support user defined config to control SSH host keys deletion + generation:
- on: ssh host key deleted + generated (compatibility: current armbian behaviour)
- off: no ssh key deleted + no ssh host key generated. Allow cloud-init to take over this behaviour deterministically.
Question
I am seeking guidance on where the user config setting should be added. Then I can write the if/else condition in the armbian-firstrun script.
Edited by David A
Solved by Igor
  • Solution
Interesting.
Perhaps extending this service?
https://github.com/armbian/build/blob/main/packages/bsp/common/lib/systemd/system/armbian-firstrun.service
At build time, this is cp to the image and enabled:
https://github.com/armbian/build/blob/main/lib/functions/rootfs/distro-agnostic.sh#L400-L401
Script:
https://github.com/armbian/build/blob/main/packages/bsp/common/usr/lib/armbian/armbian-firstrun
All those files you can edit, compile image and try. I hope this helps in some way.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
