September 17, 20242 yr I noticed the BPI-M4 Zero is supported. It's the same SoC as the BPI-M4 Berry and mostly the same hardware (8GB eMMC, 2GB RAM). The main differences seem to be the ports. Is there a chance the image would work? Is the BPI-M4 Berry possibly going to get support?
September 17, 20242 yr Wouldn't be the first time that an image for board X just works on board Y because they were close to identical hw wise. Easiest would be to simply try and check if it actually boots and which functions work and which not. Feel free to give feedback in that matter. Armbian does not accept new boards by themselves without funding. However anyone can step up and add support to the framework via pull request. Examples are here: https://docs.armbian.com/Developer-Guide_Adding-Board-Family/
