Skip to content
View in the app
Armbian Community Forums
Armbian on Cubietruck does not report battery and power values
Featured Replies
  • Author
Generally: new kernel is not populated with all features from stock.
This particular part is done but it's not function properly so it's disabled. Sooner or later it will be fixed. Maybe already is ... I need to check.
Thank you, looking forward :)
I'm also very interested in this feature, it would be very great if its comming soon.. :)
  • Author
Hello Igor,
Any idea, by when you could provide a fix?
Kind regards
Klaus
Gesendet von meinem iPhone mit Tapatalk
  • Author
Thx, and for non techies like myself :)
Is it in your actual downloadable images fixed, so I can do a new setup from scratch?
Or can you provide a step by step description how to upgrade the kernel?
Klaus
Images are two months old ... since building them is a very time consuming operations. Even the process is half automated, somebody needs to test at least some of them. Recently we only build upgrades and even that is not simple. Usually something stops working by our or by some general fault.  :mellow:  :)
Since we also change the way whole thing works it's a bit complicated (for non techies). How to build a kernel is written under documentation ... Just a tip if you go for that - you need to install all packages. If some shows you error, you need to deinstall previous version.
When upgrade will be ready, all you need will be to run apt-get update & upgrade and will work. This stage is 2-3 weeks away.
  • Author
Thx, will wait for the solution in 2-3 weeks [emoji1360]
  • Author
I've done an apt-get update and an apt-get upgrade. Kernel was updated and reboot done, but problem still not fixed.
My fault or is it still not in the distribution?
kind regards
Klaus
  • Author
Hello Skom,
is the update working with your installation?
Klaus
Three questions:
- what's in your - it should be:
s -l /etc/update-motd.d/
total 20
-rwxr-xr-x 1 root root  245 Feb 19 15:31 10-header
-rwxr-xr-x 1 root root 5474 Feb 19 15:31 30-sysinfo
-rwxr-xr-x 1 root root 4348 Feb 19 15:31 40-updates
- where is your /etc/motd linked to
motd -> /var/run/motd
- did you alter your sshd.config ?
  • Author
Hello Igor,
here are the answers:
No. 1:
# ls -l /etc/update-motd.d/
total 20
-rwxr-xr-x 1 root root  245 Feb 11 23:38 10-header
-rwxr-xr-x 1 root root 5474 Feb 11 23:38 30-sysinfo
-rwxr-xr-x 1 root root 4348 Feb 11 23:38 40-updates
No. 2:
# ls -l /etc/motd
lrwxrwxrwx 1 root root 13 Feb 13 17:24 /etc/motd -> /var/run/motd
No. 3:
just to allow root login
Klaus
  • Author
Hello again,
based on your questions I have seen, that there was only a /var/run/motd.new. Since I have copied it to /var/run/motd it shows following screen during login:
  ____      _     _      _                   _
 / ___|   _| |__ (_) ___| |_ _ __ _   _  ___| | __
| |  | | | | '_ \| |/ _ \ __| '__| | | |/ __| |/ /
| |__| |_| | |_) | |  __/ |_| |  | |_| | (__|   <
 \____\__,_|_.__/|_|\___|\__|_|   \__,_|\___|_|\_\
Welcome to ARMBIAN Debian GNU/Linux 8 (jessie) 4.4.1-sunxi
System load:   0.06            Up time:       6 days
Memory usage:  13 % of 2017Mb IP:            192.168.0.26
CPU temp:      31°C
Usage of /:    5% of 110G   Battery:       100% charged
Last login: Sat Feb 20 11:31:16 2016 from robin-air.fritz.box
looking in your 30-sysinfo script shows, that the values are stored in /sys/power/axp_pmu/battery correct?
Last question, where do I define my max battery capacity?
kind regards
Klaus
Ahaa, make a link to that file, not a copy.
For further info regarding battery, check this thread:
http://forum.armbian.com/index.php/topic/611-wip-axp209-mainline-sysfs-interface/
Battery charged rate is calculated from voltage so capacity does not matter.
How correct are the numbers is hard to say. Good enough to put some things in action when capacity drops below certain percentage. You will need a test or two to make sure.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
