October 2, 20242 yr I'm testing different firmware versions for OrangePi 3 LTS a bit and I have to mention that version: Armbian_community_24.11.0-trunk.202_Orangepi3-lts_noble_current_6.6.44_gnome-kisak_desktop.img It has a flaw that can cause some trouble for beginners, i.e. after installing, the system automatically goes to the suspend option after 15 minutesย ย ๐ Disabling the suspend option completely helps, but it then prevents you from using the suspend option by clicking the button on the board ๐ This is probably an error related to both battery and mains power supply. https://discussion.fedoraproject.org/t/gnome-suspends-after-15-minutes-of-user-inactivity-even-on-ac-power/79801 ย but unfortunately this is not it ๐ Edited October 2, 20242 yr by kris777
