Skip to content
View in the app
Armbian Community Forums
Wifi AP (on Orange Pi zero 3)
Featured Replies
The original discussion thread is this
Reposting this below just in case it may be useful
how i set it up
https://gist.github.com/ag88/de02933ba65500376d1ff48e504b1bf3
 Imho for WiFi purposes nmcli (network manager cli) is not very different from hostapd, just that hostapd possibly has more configuration options.
To setup an access point, there are quite a few pieces of network configuration that needs to be setup:
  • The WiFi AP itself (e.g. using network manager or hostapd) if you are able to connect and verify that in the log, that is probably solved. e.g.
journalctl -u NetworkManager
or for hostapd
journalctl -u hostapd
hostapd tends to have log entries for every host that connects, I'm not sure about NetworkManager.
  • DHCP (issuing IP address to connected hosts) this is particularly true for IPv4 hosts on dynamic IP.
    DHCP would likely also need to distribute the DNS server, so configure that if it isn't done.
    e.g. https://ubuntu.com/server/docs/how-to-install-and-configure-isc-dhcp-server
  • For IPv6 you may need to setup radvd (router advertisement daemon)  https://en.wikipedia.org/wiki/Radvd so that the connected hosts can setup their own IPv6 address
    quite often IPV6 requires its own /64 address range / network (* note below dnsmasq does this as well) e.g.
apt install radvd
https://wiki.archlinux.org/title/IPv6#For_gateways
  • Configure the WiFi AP as a router or bridge.
  • Router:
  • note that if you are using hostapd and not using a network bridge and there are no DHCP servers, you would need to configure the wlan0 interface with an ip address and network using say ip commands e.g.
    (ref: https://wiki.debian.org/NetworkConfiguration)
    /etc/network/interfaces
    source /etc/network/interfaces.d/*
    # Network is managed by Network manager
    auto lo
    iface lo inet loopback
    # added the following
    auto wlan0
    iface wlan0 inet static
    address 192.168.1.1
    netmask 255.255.255.0
apt install isc-dhcp-server
  • Configure routing and/or IP NAT (e.g. IP masquerading). I've tried IP NAT and that sometimes it is easier as up stream normally only a single IP address is needed.
    Routing would need a subnet to be setup, that is normally ok but that you would need to configure your main gateway router as well for the overall network setup so that it knows where/how to forward packets. many consumer getway/routers simply used NAT, that is ok as well. But that your main gateway/router may need a static route to say that for that subnet, send it to your OPi Zero 3 Wifi AP.
I've not done it completely from within nmcli for this setup as I used hostapd for the WiFi AP. But that I used nmcli (network manager) for the bridge.
But that those notes above remains similar whether you used network manager or hostapd.
take note that with hostapd for WiFi AP, you probably need to un-manage the Wifi interface in Network Manager configs so that it doesn't conflict with hostapd.
oh and when messing with network interfaces use a debug usb-uart serial dongle or you may get 'locked out' from your zero 3
Apparently, dnsmasq does all three: DNS, DHCP, RADV
https://thekelleys.org.uk/dnsmasq/doc.html
but that there may be some configurations that are needed for it to work correctly
https://docs.fedoraproject.org/en-US/fedora-server/administration/dnsmasq/
https://wiki.archlinux.org/title/Dnsmasq
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
