October 12, 20242 yr T95zPlus-h618 eth ---ok usb0&1 ---ok wifi&bt ---ok 3.5mm headphone ---ok hdmi&hdmi codec ---ok ir ---ok https://github.com/LYU4662/t95zplus-h618-build.git
May 31, 20251 yr I try your prebuild image, and no luck with wifi/Bluetooth. My tv box new revision and have YC8800D wifi chip. Can i do something to get work WiFi?
February 23Feb 23 Tried your image on an SD card but tried several way to get it to boot from SD was unsuccessful. I tried the toothpick on the button inside the 3.5 mm port. I tired ADB reboot update and ADB reboot recovery. But all those times, I just receive the android recovery menu when failed to boot SD. Is there any thing special I need to do to get this box to boot from SD? I will solder some dupont pins soon so I can get a better reading what is happening with serial console. But for now, do you know why it is so difficult to boot from SD. I never had this much issue with an AMLogic S9xx before. How can I tell if bootloader is locked? If locked what options do I have? Edited February 23Feb 23 by hieppo More to say
