Skip to content
View in the app
Armbian Community Forums
OPI 4A - Allwinner T527
Featured Replies
  • Author
I just created a new image and am reporting the following:
- On the first boot, I don't have Ethernet (I don't use wireless) and
- The eMMC is not detected.
Thanks
Quote
root@orangepi-4a:~# cat /etc/armbian-release
# PLEASE DO NOT EDIT THIS FILE
BOARD=orangepi-4a
BOARD_NAME="Orange Pi 4A"
BOARDFAMILY=sun55iw3
BUILD_REPOSITORY_URL=https://github.com/armbian/build
BUILD_REPOSITORY_COMMIT=28862c7
LINUXFAMILY=sunxi64
ARCH=arm64
BOOT_SOC=
IMAGE_TYPE=user-built
BOARD_TYPE=csc
INITRD_ARCH=arm64
KERNEL_IMAGE_TYPE=Image
KERNEL_TARGET=edge
KERNEL_TEST_TARGET=
FORCE_BOOTSCRIPT_UPDATE=
FORCE_UBOOT_UPDATE=
OVERLAY_DIR="/boot/dtb/allwinner/overlay"
VENDOR="Armbian-unofficial"
VENDORCOLOR="247;16;0"
VENDORDOCS="https://docs.armbian.com/"
VENDORURL="https://duckduckgo.com/"
VENDORSUPPORT="https://community.armbian.com/"
VENDORBUGS="https://armbian.atlassian.net/"
BOOTSCRIPT_FORCE_UPDATE="no"
BOOTSCRIPT_DST="boot.cmd"
VERSION=26.05.0-trunk
REVISION=26.05.0-trunk
BRANCH=edge
root@orangepi-4a:~#
root@orangepi-4a:~#
root@orangepi-4a:~# dmesg | grep -i mmc
[    4.418379] sunxi-mmc 4020000.mmc: Got CD GPIO
[    4.418857] sunxi-mmc 4021000.mmc: allocated mmc-pwrseq
[    4.444666] sunxi-mmc 4022000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
[    4.444692] sunxi-mmc 4021000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
[    4.445215] sunxi-mmc 4020000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
[    4.487006] mmc0: host does not support reading read-only switch, assuming write-enable
[    4.490389] mmc0: new high speed SDXC card at address aaaa
[    4.497740] mmcblk0: mmc0:aaaa SC64G 59.5 GiB
[    4.522286]  mmcblk0: p1 p2
[    4.585097] mmc2: error -110 whilst initialising MMC card
[    4.592377] mmc1: new high speed SDIO card at address 0001
[    4.596828] mmc2: Failed to initialize a non-removable card
[    7.193467] EXT4-fs (mmcblk0p2): mounted filesystem 757e37e7-0e5e-4683-8110-4a8276f032d5 ro with writeback data mode. Quota mode: none.
[   10.627502] EXT4-fs (mmcblk0p2): re-mounted 757e37e7-0e5e-4683-8110-4a8276f032d5 r/w.
[   12.277240] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43456-sdio.xunlong,orangepi-4a.bin failed with error -2
root@orangepi-4a:~#
root@orangepi-4a:~#
root@orangepi-4a:~# uname -a
Linux orangepi-4a 7.0.0-rc6-edge-sunxi64 #2 SMP PREEMPT Sun Mar 29 22:40:00 UTC 2026 aarch64 GNU/Linux
root@orangepi-4a:~#
Edited by JamesCL
@Werner I imagine there are plenty of people here who could help solve similar problems. In theory, I could provide a pair of an old RPI (master) and a 4A (slave), with the slave serial connected to the master and power controlled via the GPIO, and they are also on the same VLAN. However, if something goes wrong it needs control to the slave's SD card, all I've found is an SD card extender, and it needs something like an emulator that connects to the master via the same USB/SPI.
Things are still very sad with Ethernet. Is this could be related to some low-level timings in device configuration?
Edited by sergiyd
extraargs=nvme_core.default_ps_max_latency_us=0 pcie_aspm=off pcie_port_pm=off
to /boot/armbianEnv.txt
fixes nvme detection
the temperature is
echo "$(( $(cat /sys/class/hwmon/hwmon0/temp1_input) / 1000 )) °C"
if you copy the system to nvme and wanna boot with microsd (spi doesn't work for now):
1) it will actually boot but without boot mountpoint
2) mount /boot and /media/mmcboot manually
3) fix fstab
Edited by Evgeniy evotronik
to start ethernet
#!/bin/bash
echo -n "4510000.ethernet" > /sys/bus/platform/drivers/dwmac-sun55i/unbind 2>/dev/null
echo 271 > /sys/class/gpio/export 2>/dev/null
echo out > /sys/class/gpio/gpio271/direction 2>/dev/null
echo 0 > /sys/class/gpio/gpio271/value 2>/dev/null
sleep 0.1
echo 1 > /sys/class/gpio/gpio271/value 2>/dev/null
sleep 0.3
echo 271 > /sys/class/gpio/unexport 2>/dev/null
echo -n "4510000.ethernet" > /sys/bus/platform/drivers/dwmac-sun55i/bind 2>/dev/null
just systemd it
[Unit]
Description=Fix ethernet PHY on cold boot
After=multi-user.target
[Service]
Type=oneshot
ExecStart=/usr/local/bin/fix-eth.sh
RemainAfterExit=yes
[Install]
WantedBy=multi-user.target
  • Author
Hi ...
Thanks @Evgeniy evotronik. Yesterday I downloaded the image "Armbian_community_26.2.0-trunk.886_Orangepi-4a_trixie_edge_7.0.5_minimal.img.xz", but the Ethernet and eMMC issues are still present. I will apply the Ethernet patch.
Thanks again.
  • Author
The eMMC is still not detected.
Kernel log:
[    4.621568] mmc2: error -110 whilst initialising MMC card
[    4.627066] mmc2: Failed to initialize a non-removable card
Working devices:
[    4.502846] mmc0: new high speed SDXC card at address aaaa
[    4.508907] mmcblk0: mmc0:aaaa SC64G 59.5 GiB
[    4.551951] mmc1: new high speed SDIO card at address 0001
The system boots correctly from the SD card, but the onboard eMMC (mmc2) is not initialized.
There are also still Ethernet issues. After connecting through PuTTY, the system sometimes hangs when running dmesg, and the network connection becomes unstable or unresponsive.
System information:
Quote
Linux orangepi-4a 7.0.7-edge-sunxi64 #1 SMP PREEMPT Thu May 14 13:31:20 UTC 2026 aarch64 GNU/Linux
root@orangepi-4a:~# cat /etc/os-release
PRETTY_NAME="Armbian_community 26.2.0-trunk.904 trixie"
NAME="Debian GNU/Linux"
VERSION_ID="13"
VERSION="13 (trixie)"
VERSION_CODENAME=trixie
DEBIAN_VERSION_FULL=13.4
ID=debian
HOME_URL="https://www.armbian.com"
SUPPORT_URL="https://forum.armbian.com"
BUG_REPORT_URL="https://www.armbian.com/bugs"
ARMBIAN_PRETTY_NAME="Armbian_community 26.2.0-trunk.904 trixie"
root@orangepi-4a:~#
Thanks
guess it kernel/driver issue
The driver does not request the stmmaceth (emac1-25M) clock during probe. Without this clock the MDIO bus does not function on cold boot - PHY ID reads as 0x00000000 and kernel falls back to Generic PHY instead of YT8531. Ethernet does not work until warm reboot.
This device is currently an outcast here, and until someone with understanding sets out to fix at least the main problems, welcome to the official image on the 5.15 kernel.
Greetings - just investigating an issue with the opi-4a Armbian 26.8.0 minimal (edge 7.0.12) build - not getting past starting kernel.  The board has a T527 - Hopefully this information is useful ?
### [Bug Report] Orange Pi 4A - Silent Hang at 'Starting kernel ...' (Trixie Minimal)
**Board:** Orange Pi 4A (Allwinner A523/T527)
**Image used:** Debian Trixie Minimal (Built via armbian-imager)
**Installation Media:** SD Card (Class 10)
**Log Type:** UART Serial Console Output (115200 baud)
#### Description of Issue
The recent community build of Debian Trixie Minimal for the Orange Pi 4A successfully clears the U-Boot / SPL stages, loads the Ramdisk and DTB from the SD card, but hangs completely silently immediately after hitting `Starting kernel ...`. The onboard status LED remains solid red with no flashing activity.
#### The Technical Root Cause
Looking closely at the UART initialization text, there appears to be a mismatch between the SoC detected by the low-level firmware and the Device Tree Blob (DTB) loaded by the Armbian boot script:
1. **Firmware/U-Boot Chip Detection:** TF-A and U-Boot explicitly identify the SoC as an **Allwinner A523**:
   ```text
   NOTICE:  BL31: Detected Allwinner A523 SoC (1890)
   CPU:   Allwinner A523 (SUN55I)
2. **Script DTB Selection:** Immediately afterward, the automated script loads a **T527 DTB** profile:
   ```text
   Load fdt: /dtb/allwinner/sun55i-t527-orangepi-4a.dtb
Because the kernel tries to initialize the primary power rails and clock gates using a T527 map on an A523 layout, the CPU locks up silently at the execution handoff.
#### Complete Boot Log (Up to the Hang)
```text
U-Boot SPL 2026.01_armbian-2026.01-S127a-P60fe-Hc6a9-Vf757-Bd0d2-R448a (May 30 2026 - 05:53:33 +0000)
DRAM: 2048 MiB
Trying to boot from MMC1
NOTICE:  BL31: v2.13.0(debug):armbian
NOTICE:  BL31: Built : 05:52:43, May 30 2026
NOTICE:  BL31: Found U-Boot DTB at 0xa0b8ac0, model: OrangePi 4A
INFO:    Configuring SPC Controller
INFO:    BL31: Platform setup done
INFO:    GICv3 without legacy support detected.
INFO:    ARM GICv3 driver initialized in EL3
INFO:    Maximum SPI INTID supported: 287
INFO:    BL31: Initializing runtime services
INFO:    BL31: cortex_a55: CPU workaround for erratum 1530923 was applied
INFO:    PSCI: Suspend is unavailable
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x4a000000
INFO:    SPSR = 0x3c9
U-Boot 2026.01_armbian-2026.01-S127a-P60fe-Hc6a9-Vf757-Bd0d2-R448a (May 30 2026 - 05:53:33 +0000) Allwinner Technology
Model: OrangePi 4A
DRAM:  2 GiB
sunxi_set_gate: (CLK#35) unhandled
Core:  94 devices, 24 uclasses, devicetree: separate
WDT:   Not starting watchdog@2050000
MMC:   mmc@4020000: 0, mmc@4021000: 2, mmc@4022000: 1
Loading Environment from FAT... Unable to read "uboot.env" from mmc0:1...
In:    serial@2500000
Out:   serial@2500000
Err:   serial@2500000
Net:   No ethernet found.
starting USB...
USB EHCI 1.00
USB OHCI 1.0
USB EHCI 1.00
USB OHCI 1.0
Bus usb@4101000: 1 USB Device(s) found
Bus usb@4101400: 1 USB Device(s) found
Bus usb@4200000: 2 USB Device(s) found
Bus usb@4200400: 1 USB Device(s) found
Hit any key to stop autoboot: 0
PCIe: Acquiring resources...
PCIe: Failed to get switch-sel GPIO: -2
PCIe: Hardware init failed with error -2
Device 0: unknown device
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
4641 bytes read in 2 ms (2.2 MiB/s)
U-boot loaded from SD
Boot script loaded from mmc
249 bytes read in 2 ms (121.1 KiB/s)
33383 bytes read in 7 ms (4.5 MiB/s)
Working FDT set to 4fa00000
Failed to load '/dtb/allwinner/overlay/sun55i-t527-fixup.scr'
16748327 bytes read in 814 ms (19.6 MiB/s)
41171456 bytes read in 1707 ms (23 MiB/s)
Moving Image from 0x40080000 to 0x40200000, end=0x42a30000
## Loading init Ramdisk from Legacy Image at 4ff00000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Data Size:    16748263 Bytes = 16 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 4fa00000
   Booting using the fdt blob at 0x4fa00000
   Loading Ramdisk to 49007000, end 49fffee7 ... OK
   Loading Device Tree to 0000000048f96000, end 0000000049006fff ... OK
Working FDT set to 48f96000
Starting kernel ...
 Greetings
### [Follow-up Update] Boot Deep-Dive via Cubie-A5E DTB Masking
Following up on my previous boot freeze post, I (with some assistance from Gemini - who formatted this post) managed to force the Armbian kernel to initialize by masking the sister chip profile (`sun55i-a523-cubie-a5e.dtb`) over the broken `sun55i-t527-orangepi-4a.dtb` target and injecting `clk_ignore_unused` / `irqpoll` parameters.
This got us past the initial handoff hang and successfully spawned the 8-core CPU array initialization and initramfs launch (`Run /init as init process`), but the system eventually hit a permanent deadlock during the device probe phase.
I don't think I can get this to go any further without some many hours spent looking at how these things work and its currently 35 degrees C here in the UK so time for a beer methinks!
#### Full Boot Log Paste Link: - this is the log before using irqpoll parameter (which eventually caused a deadlock) - I can post the irqpoll logs although i wouldn't have thought irqpolling is the way to go ?
https://pastebin.com/TvxTxdbp
### Either way - having just read that this post refers to irqpoll then this is the boot logfile with irqpoll added an an extraparm
https://pastebin.com/TNS3DDTC
#### Key Technical Takeaways from the Log Dump:
1. **PMIC / I2C Communication Failures:**
   The kernel initializes the AXP717 and AXP323 power chips but encounters standard timeout errors right away:
   ```text
   axp20x-i2c 0-0034: AXP20x variant AXP717 found
   axp20x-i2c 0-0034: Failed to set masks in 0x40: -6
   axp20x-i2c 0-0034: failed to add irq chip: -6
2. **MMC / Storage Controller Deadlock:**
   Because the AXP717 framework drops out and the Cubie pin definitions do not line up with the Orange Pi 4A's physical board wiring, the kernel enters an endless loop waiting for internal voltage rails (`cldo3` and `bldo1`) to power up the storage controller:
   ```text
   platform 4020000.mmc: deferred probe pending: platform: wait for supplier /soc/i2c@7081400/pmic@34/regulators/cldo3
   platform 4021000.mmc: deferred probe pending: platform: wait for supplier /soc/i2c@7081400/pmic@34/regulators/bldo1
   This prevents the storage device slot from spinning up, trapping the system right as it attempts to mount the root filesystem.
Hopefully this helps isolate the unaligned power configuration loops and clock tables in the current `armbian-imager` source profile for the OPi 4A!
Title: [Working Image + Patch] Orange Pi 4A (T527) - Fast Ethernet Fixed on Mainline 7.0 Edge
Hi everyone,
Since the Orange Pi 4A (Allwinner T527) is currently an unmaintained community target on the bleeding-edge Mainline 7.0 Edge branch, the default images boot up completely blind with cannot attach to PHY (error: -ENODEV) errors.
After a lot of debugging, I (with assistance from Gemini - who wrote this post) managed to successfully compile a full, functional Debian Trixie image where Ethernet works perfectly (capped at 100M) and the green status LED pulses a native heartbeat.
The secret sauce is that the board uses a Motorcomm YT8531 transceiver, but the kernel falls back to a Generic PHY driver which fails to calibrate the high-frequency RGMII clock skews required for Gigabit speeds. Dropping the link frequency down to 100 Mbps Full Duplex bypasses the timing sensitivity completely, allowing NetworkManager to instantly pull a stable IPv4 DHCP lease!
(Note: Mainline 7.0 does not yet have internal C drivers for the T527 audio codec or the SDIO mmc1 bus clocks, so internal audio and onboard Wi-Fi remain offline. Use a USB sound/Wi-Fi dongle if needed).  I can't vouch whether HDMI is working or not as I was debugging it using a serial cable.
📦 Download the Image
https://drive.google.com/drive/folders/1ieu3TBn2nSP0BaJvJMIhLeLM6kt-x8bX?usp=sharing
🛠️ The Device Tree Patch File
I managed to diff the radxa-cubie-5e.dts file and patch it to get it to kind of work with the opi 4a.  The patchfile is also in the google drive folder and supplied as an attach here.
To include this in your own Armbian build environment, delete any old patches and save this file exactly as:
build/userpatches/kernel/archive/sunxi-7.0/zzzz-working-opi4a.patch
It wipes out the broken default configurations and replaces them with clean, compiling mainline mappings.  You can then build the image using this:
./compile.sh build BOARD=orangepi-4a BRANCH=edge BUILD_DESKTOP=no BUILD_MINIMAL=no KERNEL_CONFIGURE=no RELEASE=trixie USERPATCHES_ALLOWED=yes SYSTEM_VERBOSE=yes FORCE_REBUILD=yes
📝 Step-by-Step Instructions to Lock Down the 100M Connection
Because the Generic PHY driver cannot process 1Gbps packets correctly, the interface will sit in an unconfigured DOWN loop upon initial boot. Run these steps via your serial terminal loop to bring it online and automate it:
Force the hardware down to 100M to clear the packet queue:
sudo ethtool -s end0 speed 100 duplex full autoneg off
Tell NetworkManager to explicitly negotiate the port:
sudo nmcli device connect end0
Make the 100M setting permanent so it survives a reboot:
sudo nmcli connection add type ethernet con-name eth-100m ifname end0 802-3-ethernet.auto-negotiate no 802-3-ethernet.speed 100 802-3-ethernet.duplex full ipv4.method auto ipv6.method disabled
Automate the green status heartbeat LED:
Open /etc/rc.local
and add this line right above exit 0
echo heartbeat > /sys/class/leds/green:status/trigger
Reboot, and you should have a 100% automated, maintenance-free, fully operational network target - with some tweaking will hopefully get you to the next stage as apt will be working. Hope this helps anyone else struggling to get this community board running on modern releases!
zzzz-radxa-to-orangepi4a-fix.patch
Just managed to distract myself some more in this outrageous heat here in the UK and can confirm that the RELEASE=stable (6.18) build (from compile.sh) boots ok after some tweaking.  It got stuck on "Starting Kernel" but when I added these lines to /boot/armbianEnv.txt to see why it failed, then it booted ok - dunno why.  I think keep_bootcon was the important bit.
extraargs=earlycon=uart8250,mmio32,0x02500000 keep_bootcon ignore_loglevel loglevel=8
The other problem then was getting the ethernet to work which I did by creating a device tree overlay file - much the same as other here is it only seems be working at 100M unlike the 1000M in the 5.15 kernel.  The extra problem seemed to be that the wifi driver would periodically crash and cause a kernel-panic.  The following DTS file pulls the ethernet down  to 100M and disables the wifi to stop it crashing.  You then compile this into a .dtbo file, copy it to /boot/overlay-user and reference it in armbianEnv.txt with this line
user_overlays=opi4a-network-fix
The opi4a-network-fix.dts syntax to create it is as follows ... apart from that I can't get it to do much more, so will go down the 5.15 bookworm route until things change
/dts-v1/;
/plugin/;
   compatible = "xunlong,orangepi-4a", "allwinner,sun55i-t527";
   /* Maintain working Ethernet at 100M address 1 */
   fragment@0 {
       target-path = "/soc/ethernet@4510000";
       __overlay__ {
           phy-mode = "rgmii-id";
           phy-handle = <&ext_rgmii_phy>;
           status = "okay";
           mdio {
               #address-cells = <1>;
               #size-cells = <0>;
               ext_rgmii_phy: ethernet-phy@1 {
                   compatible = "ethernet-phy-ieee802.3-c22";
                   reg = <1>;
                   max-speed = <100>;
   /* Hard disable the unstable wireless MMC controller block */
   fragment@1 {
       target-path = "/soc/mmc@4021000";
       __overlay__ {
           status = "disabled";
Hi — I've been following this thread, the 100 Mbit ethernet cap and the silent mainline boot hang especially. I ended up doing a full mainline bring-up of the 4A on 6.18.38 and got gigabit ethernet working properly (RX/TX), plus the boot hang sorted, so I wanted to share the whole patch series in case it helps here.
Full disclosure: I'm not a kernel developer by trade — I got most of this working with a lot of help from AI coding agents, leaning hard on the BSP 5.15 as the source of truth. In my own testing everything seems stable, but I'd genuinely welcome anyone who actually knows this stuff to review the patches and tell me what I got wrong or did in a hacky way. No egos here — I'm sharing it in case it's useful and to get feedback, not claiming it's perfect. 🙂
What works (confirmed on hardware):
  • HDMI KMS display (DE33/DE3.5 + TCON-TV + DW-HDMI 2.0 + Inno PHY) — 720p/1080p, clean VSU8 scaling
  • GPU Mali-G57 (Panfrost) — accelerated (KDE Plasma Wayland)
  • HDMI audio (i2s2 → dw-hdmi) — PCM out to the TV
  • Ethernet GMAC1 (YT8531 PHY, RGMII) — full gigabit RX/TX
  • WiFi AP6256 (BCM43456, brcmfmac, SDIO) — 2.4/5 GHz scan + assoc
  • reboot / poweroff (sunxi_wdt / AXP717)
  • AFBC scanout (v350 AFBD decoder)
  • USB — the 4 rear ports (all USB 2.0; the board doesn't wire the SoC's USB3) — HID + mass storage, hotplug
  • THS thermal sensors (5 zones: cpu_l / cpu_b / gpu / npu / ddr) + 110 °C critical trip
  • CPU cpufreq/DVFS (little cluster up to 1.416 GHz, big cluster up to 1.8 GHz) + thermal throttling
  • GPU devfreq/DVFS (Panfrost, 150–600 MHz) + thermal throttling
  • HDMI HPD / hotplug (native, no force)
Known not working / help wanted:
  • eMMC — not tested (I don't have a module). I saw the mmc2: error -110 reports earlier in the thread; happy to dig into it with anyone who has eMMC.
  • Hardware video decode (VPU) — no driver in 6.18 yet (software decode works).
  • Suspend/hibernate — untested.
  • 4GB variant — expected to work out of the box (the bootloader auto-detects the RAM size and fills in /memory at boot; verified over UART on the 2GB board). I only own the 2GB variant, so if you have the 4GB one, a free -h confirmation would be very welcome.
  • NVMe SSD — untested, no drive here. Everything so far has only run from microSD.
Freshness note: the cpufreq/thermal/GPU-devfreq block landed this very week and is still under soak testing on my board — everything else has more mileage. I'll report anything that shakes out in this thread.
Repo / patches: https://github.com/ut-slayer/orangepi-4a-mainline
It's a git format-patch series (~106 patches) on top of 6.18.38 vanilla, plus a defconfig and the board .dts. The README groups the patches by intended destination: generic sunxi fixes (pinctrl, watchdog vs PSCI, AXP717 poweroff, a RESET_GPIO/mmc-pwrseq bug affecting any sunxi board with SDIO WiFi), the HDMI KMS display series (largely ported/adapted from the minimyth2 / Justin Suess H728 work, with original authorship kept in the patch headers), the A523 CPU CCU + thermal + DVFS, board integration (dts + defconfig), and a few U-Boot BSP workarounds that go away with mainline U-Boot.
Coming next: a ready-to-flash Debian 13 (Trixie) image with accelerated Panfrost and KDE Plasma on Wayland — I'll share it in this thread once it's had a bit more soak testing.
Happy to open a PR against armbian/build (sun55iw3 family) with the board dts + defconfig + patches if there's interest. Feedback and testers welcome!
Credits: minimyth2 / Justin Suess for the H728 display groundwork, and the linux-sunxi community.
Cheers.
Edited by AurealNix
@AurealNix - great effort and thanks for putting me in touch with Claude 5, I was just using Gemini and it was struggling a fair bit!!   In fact I had just put this board on ebay as it was causing too much distraction so your last two posts looked hopeful.  Sorry my spanish isn't that great so I'll stick with English.
I was hoping to just put these 106 patch files directly into the userpatches/kernel/archive/sunxi-6.18 folder and then run compile.sh with USER_PATCHES=yes, but that didn't work as patch files in that location seem to be tempremental and it couldn't find a lot of the targets.    I tried removing the ones with errors which didn't work either, so went down the route of adding running compile.sh with kernel-patch parameter then copying your sun55i-t527-orangepi-4a.dts into
./cache/sources/linux-kernel-worktree/6.18__sunxi64__arm64/arch/arm64/boot/dts/allwinner/sun55i-t527-orangepi-4a.dts to get a new patch file, but this failed to compile likely because it doesn't have the changes you made to the .dtsi and other files .
It would be good to know how you and Claude were building the kernel - I can see in your README that you are doing it directly into linux 6.18.38 tree, whereas I was working out of a clone of armbian in github.  I would like to spend more time on this but  need to get onto the real reason I bought the board (an outdoor noise cancelling project) so I'm going to use another board in the meantime.
Cheers
Hi @bickns, thanks a lot for giving it a go! 🙏 The reason dropping them into userpatches/kernel/archive/sunxi-6.18 fails is that these aren't Armbian-style patches — they're a git format-patch series on top of plain vanilla 6.18.38 (base commit 1db74811b), meant to be applied to a clean tree in order. Armbian applies its own sunxi patch set first, so they conflict against that.
I didn't use the Armbian build system at all — I built mainline from scratch:
Clone/checkout vanilla 6.18.38, then git am /path/to/patches/0*.patch (all 106, in order).
Copy opi4a_blindboot_defconfig into arch/arm64/configs/ and make opi4a_blindboot_defconfig.
make ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- -j$(nproc) Image dtbs modules
Wrap it for the BSP U-Boot (this is the important bit — it only boots a legacy uImage): mkimage -A arm -O linux -T kernel -C none -a 0x41000000 -e 0x41000000 -d arch/arm64/boot/Image uImage
Two things to know:
A handful of the patches are BSP-U-Boot workarounds (static /memory, display FDT stubs, etc.) — only needed to boot under the proprietary BSP U-Boot. If you're on mainline U-Boot / a normal Armbian boot flow, you'd skip those. The README groups the patches by destination so you can see which is which.
If you want to integrate into Armbian proper, the cleaner path is probably the board DTS + defconfig + the generic sunxi fixes as individual patches, rather than the whole display series in one go (that one's a big port of the minimyth2/Suess work and would need adapting to Armbian's tree).
Happy to help however's useful — glad it's of interest!
Edited by AurealNix
you fancy a fun distraction rather than a frustrating one: I'm also putting together a retro-gaming image for this SoC (HDMI to the TV + a gamepad = a neat little emulation box, and it's the same chip as some of the new handhelds). Early days, but it's in the works — one more reason to keep the board out of the eBay pile. 🙂
Thanks @AurealNix - that's good intel.    Only 20 of those patches of the 109 failed - I had a quick look through them and I can see you are looking to prioritise the GPU (all those GOOGLE_ flags to make youtube stream better etc)  amongst other things.  For my project I only needed to run headless so I could install your image and uninstall KDE if it didn't work out with my current prototype for this outdoor noise cancelling thing (I was attracted to the opi 4a because it had a bit more all round grunt)
I figured I'd stick with armbian as it would have a better chance of the PR for changes to dtb etc being accepted into "stable".. I think I might go with your .dts and manually apply the changes to the other files  and then build from there - used to have the stomach for this back in the day when I used to hack stuff before the internet, but I really need to get onto the noise cancelling project as my wife complains about the noise of the road when we have a BBQ outdoors and I reckon i could go some way to disturb that with some software.
Your retro gaming image sounds top notch!  I'm still to Master Halo 4 on the X-Box one given all these other distractions.  The board is now in the bottom drawer for now as the DJI Mic Mini 2 just turned up today and the other board recognises it ok  and its on to stage 2 of this prototype.  Enjoy the football .. Cheers
@Nick_Sl @bickns — CLI/headless image is coming. It's the same debootstrap base and the same kernel, just without Plasma/Mesa/Discover, so it's mostly "subtracting", not extra work — a small ~300–500 MB image. Nick, I'll ping you when there's something to test. 🙂
Before I build it: is there anything you'd want baked in by default? Thinking headless/server use — things like NetworkManager vs systemd-networkd, docker/podman, python3, build tools, an ssh-only footprint, zram on by default, etc. If you tell me your use case I'll pick sane defaults rather than guessing.
Good news on audio in the meantime: both HDMI and the analog 3.5 mm jack are working now (with jack-detect hotplug), so that's no longer a blocker for either image.
@Nick_Sl @bickns — no more waiting, the headless build is up. 🙂
It's a CLI / headless image for the Orange Pi 4A: pure Debian 13 (a debootstrap minbase — bare on purpose, add the rest with apt), the full mainline 6.18.38 kernel, SSH on from first boot. 146 MB compressed, idles at ~180 MB of RAM. Same kernel as the desktop image (HDMI, WiFi/BT, gigabit ethernet, USB, thermal + CPU/GPU frequency scaling) — just no desktop.
It's the ...-cli-v0.2.img.xz asset here (the desktop image is on the same page): https://github.com/ut-slayer/orangepi-4a-mainline/releases/tag/v0.2
Whoever gives it a spin: I'd really appreciate the feedback — especially if something doesn't work quite right. A lot of this only shakes out once other people run it on their own boards, so bug reports are genuinely welcome (here or on the GitHub issues).
@bickns — "no special requests, apt adds the rest later" was exactly the design goal, so we're on the same page: it's a minimal base and nothing more. If you're still doing your own build for the Armbian-stable PR, the tip stands — for a headless target you can drop the whole display/GPU series (drm/sun4i + iommu + clk), which is where most of your ~20 rejects were coming from; you only need the dts + the ethernet/wifi/usb/thermal/cpufreq bits. One thing that's right up your alley given your outdoor-audio project: the A523 analog codec now has a working driver (ported from the BSP). Headphone output and jack-detect are validated on hardware; mic capture is wired in the driver but I couldn't bench-test it (no onboard mic here). You'd be the ideal person to confirm whether capture works — if it does, that's the last gap on this codec closed.
@Nick_Sl — you said you could wait; turns out you don't have to. 🙂 If you're still up for testing, I'd genuinely love your results — flash it, SSH in, and tell me what breaks (especially on the 4 GB variant if that's what you have).
Glad the board's out of the eBay pile.
I had quick look at both new version 0.2 version.
The CLI version boots up no issue, hdmi output works. Well test further.
The KDE version, I get an error using BalenaEtcher writing the image to the SD.
Also can you provide the root password? ( just notice Root is locked )
Edited by L. Jorge Soares
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
