February 13, 20251 yr Hi, anyone have already connected a speaker to gpio of lcpi h3 v8 (like orange pi pc). I have tried but im not sure if i2s is enabled on armbian
February 14, 20251 yr moved If it is a 1:1 clone of opi pc check if i2s overlay is enabled. Try armbian-config or the manual way by setting in /boot/armbianEnv.txt Check /boot subfolders for available overlays.
February 14, 20251 yr Author i have added to armbianEnv.txt overlays but i2s still disabled thanks for your time
February 14, 20251 yr There are multiple lines starting with overlay= Put all in one line like overlays=uart1 uart2 uart3 uart4 i2s i2c whatever Make sure the enabled overlays don't share same GPIO pins. Check your boards datasheet/manual.
