March 16, 20251 yr When I check the eMMC from the Disk utility, it shows that it's normal. I can also boot the android distro that came with it normally.  Help? 🥲
March 16, 20251 yr AFAIK armbianinstall expects an empty eMMC without partitions. This should be easily achievable by overwriting the first few sectors of it. Like dd if=/dev/zero of=/dev/mmcblkX bs=512 count=1 A reboot might be required to make the OS aware of the altered partition table. Then retry installing.
March 16, 20251 yr Author Well turns out my eMMC drive is mounted at /dev/mmcblk0p1...but armbian-config tries to install at /dev/mmcblk0p2, which doesn't even exist (Nevermind df command didn't show it but fdisk -l did) Edited March 16, 20251 yr by devmichelcastilho typo
March 16, 20251 yr Author I've overwritten the first few sectors of mmcblk0p2 as suggested, rebooted and tried again, same result. Â Deleted all partitions, rebooted and tried again, same result and this returned: Â Quote [ 151.337977] ext4: Unknown parameter 'compress-force' Â
March 17, 20251 yr Author Solution I had installed stuff and slightly increased the system space usage, it's likely it was bigger than the partition created for the system on the eMMC. Since the whole system is copied as is, I assume it tried to copy the whole thing with the additional stuff and went over the available space. After flashing a fresh install into the SD card, I tried it again and it worked first try.
March 17, 20251 yr 5 hours ago, devmichelcastilho said: I assume it tried to copy the whole thing Single board computers are purpose oriented devices, where booting and using live OS is common. This is how installer was designed -Â you can boot and run OS from SD card. And move OS to internal memory at any moment - freshly & clean, after one year, never.
