Skip to content
View in the app
Armbian Community Forums
Root by UUID leftovers and using armbianEnv.txt for more targets
Featured Replies
If I checked the configuration correctly, only Cubox, S500 and Udoo* don't have HAVE_UUID_SUPPORT=yes set, but AFAIK all boot scripts now load the initrd.
@Igor can you add and test root by UUID on those boards?
Also boot scripts for more boards could use /boot/ambianEnv.txt, I already tested it on XU4 and will try to test it on C2, will anybody be able to test it on C1 or C0 (it has much older u-boot)?
If I remember correctly there were some problems either on Cubox or Udoo, but hopefully it can work on most of the left over configurations.
  • Author
2 minutes ago, Igor said:
Cubox is critical since they use pre historic u-boot.
I wouldn't call Cubox 2013.10-rc4 prehistoric because C1 uses 2011.03 :)
If there are problems overwriting existing environment variables with "env import" it may be caused by some compile-time settings.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
