March 19, 20251 yr hi folks I've installed the pi-hole version that you guys have kindly delivered through the extra software I can't make it work with the default docker 'virtual network' how can I change it so that docker uses the host network?? I worked out that pi-hole is started using a start.sh but I looked at it and it's double dutch to me! cheers
